Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
Thread: 2015 Broken my families
    Moderator mark b's Avatar
    NSW Australia
    1,436
    09:46 PM
    Just upgraded my 2014 window and door families to 2015 and have just noticed that the process has broken the association of my nested components (frame, architraves, sills etc.). "throat by host" / "if throat not by host" parameter are not working. Seems if I open each component, change something, reload, then accept update parameters then all good, now I only have to do this about 1200 times. Not happy!!!!
    Anybody else?
    2,847
    08:46 PM
    you have 1200 window and door families???
    Austin, Texas
    292
    04:46 AM
    Using Aaron's doors and the "throat by wall size" parameter is not working
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    02:46 AM
    I think I mentioned it in a post a while back that they would switch how that reporting parameter worked....
    I was right, I have to dimension to the wall again and not the reference plane
    Edit: All windows flipped during the upgrade process too..
    Las Vegas, NV
    4,864
    02:46 AM
    So on a new project, all my doors work like they should. The upgraded project the doors lose their hosting ability. I have to change what the reporting parameter is being dimensioned to then reload the offending frame and it updates just fine.
    NSW Australia
    1,436
    09:46 PM
    Quote Originally Posted by Rick Moore View Post
    I made my doors and windows from sctarch using Aarons methods and similar terminology so nice to see someone else has the issue and its not the way I constructed mine. Obviously a 2015 issue as they were upgraded from 2013 to 2014 no problem
    Thanks for the heads up will investigate the "Reporting Parameter" theory tonight.
    Elton
    No I don't have 1200 doors and windows (slight exaggeration) but if I have to reload every component that relys on a reporting parameter then it might as well be 1200.....
    NSW Australia
    1,436
    09:46 PM
    Just to confirm, I have found that if edit my door (or window) then edit the Frame / Opening family, the just uncheck (or check dosen't matter which) the "Door_ Throat by Host" yes / no parameter, them reload frame back, then accept override parameters, the every thing works fine without re referencing the reporting parameter. Just seems it wants to be "refreshed" either way ADSK have created a hell of a lot of work for me to correct this throughout my library. Won't be migrating to 2015 till its done.
    Edit:-
    Updating an old project breaks um too......
    Alex Cunningham's Avatar
    Northern California
    3,576
    03:46 AM
    Elton
    **** hole!!! We modeled our door families using Aaron's doors as well. I hope ours don't implode.
    11,463
    04:46 AM
    Thats odd. Ive upgraded a few projects here and havent had that trouble, but i was updating them to the last pre-release version. I havent updated anything to Full RTM yet (waiting on IT to get the licenses on the server). Ill check some files tomorrow.
    If the doors need to get repaired and re-uploaded, ill do that later in the week.
    NSW Australia
    1,436
    09:46 PM
    Aaron like I said I am not using your doors so don't repair on my account, I have done my doors and windows from scratch but modeled the same as yours and have worked fine through 2013 and 2014 versions.
    Last Post: March 28th, 2014, 01:15 AM
    Last Post: March 25th, 2014, 02:45 AM
  3. 3D View and Brain are both broken
    Last Post: December 19th, 2013, 08:01 PM
  4. Why is this Family broken?
    By Tim West in forum Architecture and General Revit Questions
    Last Post: November 8th, 2012, 06:56 PM
  5. Fixing a broken model
    By Randy_CaS in forum Architecture - Family Creation
    Last Post: July 13th, 2011, 08:08 PM
