Thread: Annotation Families & Filled Regions
    Junior Member Matt_Short's Avatar
    February 4, 2014
    Houston, Tx
    33
    09:46 AM
    Good Morning All,
    I am placing a key plan within my title block family that needs to only be visible on certain sheets. I would like to use an instance based parameter to control the JPEG reflecting the site. I understand that to control a JPEG it needs to be an annotation family. The problem is that when I created the family using the JPEG, I can no longer see the filled regions I am using to highlight different areas of the site. In other words, it is affecting the draw order of my key plan. Is there a way to pull these filed regions back on top of my annotation family ?
    February 4, 2014
    Houston, Tx
    33
    09:46 AM
    Chirp Chirp
    Alex Cunningham's Avatar
    Northern California
    3,574
    07:46 AM
    Nest your JPEG into another family.
    February 4, 2014
    Houston, Tx
    33
    09:46 AM
    I did that but now the filled regions I am trying to use for my key plan are "behind" that nested family.
    February 2, 2011
    Montreal/Paris
    829
    10:46 AM
    Get rid if the jpg and redraw it in Revit. It will take you less time then going through this discussion and everything will work fine.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    07:46 AM
    Guessing the jpeg is the existing site? Because you have to deal with the display order I would suggest using Legends instead of an annotation symbol. You will have to create multiple legend views though to highlight what you want. But display order works.
    February 4, 2014
    Houston, Tx
    33
    09:46 AM
    I ended up linking parameters through the nested JPEG family, in to my title block.
  1. Combine 2 filled regions
    By Jock in forum Architecture and General Revit Questions
    Last Post: November 27th, 2013, 02:52 PM
  2. Cannot tag over filled regions?
    Last Post: October 15th, 2013, 09:11 PM
  3. Filled Regions that aren't showing up under Families
    Last Post: May 29th, 2013, 07:49 PM
  4. Parametric Filled Regions???
    Last Post: April 21st, 2012, 06:50 AM
  5. Filled Regions and Floors
    By retroface in forum Architecture and General Revit Questions
    Last Post: June 17th, 2011, 02:49 PM
