Results 1 to 9 of 9
Thread: Please Help Working on my first revit project and need help on the rood
    May 1, 2014
    03:04 PM
    Hello I'm working on my first ever project and I'm struggling with the roof. The roof I'm going after is Screenshot by Lightshot and what I keep ending up with is a roof not even close with wall openings. Please could you help me out, thanks
    Dl: https://www.dropbox.com/s/5cyd2f5n04...ign_VH8901.rvt
    Thanks a bunch to whoever can help me out with this. Ive tried and tried for countless hours/
    Member Nevin's Avatar
    April 13, 2014
    Qld, Australia
    63
    01:04 AM
    It looks pretty simple to me.
    Try looking up some tutorials on youtube.
    1,628
    05:04 PM
    I'd say create 3 separate pieces of roof and use the roof slope arrows. instead of the 'defines slope' thing. This way you can set different slopes for the different pieces of roof (something you will have to do in this case I believe).
    Splitting up the roof is probably not really needed, but makes it easier to work with in my opinion.
Name:	roof slope.png
    April 13, 2014
    Qld, Australia
    63
    01:04 AM
    So much easier than that. simply draw the outline how you want it and where you want the gable ends simply uncheck defines slope. you may need to use a roof by extrusion to fill in underneath the larger gables but you would just follow the profile of the main roof.
    April 13, 2014
    Qld, Australia
    63
    01:04 AM
    like so.....
ID:	17225   Click image for larger version.
    November 12, 2012
    Bengaluru
    41
    08:34 PM
    Quote Originally Posted by nolanconcepts View Post
    My best suggestion is to use roof soffit command the join gometry make them one
    Go through attached image
Name:	Roof Soffit.JPG
    1,628
    05:04 PM
    I think that in this case the soffit is not the issue, but the fact that the 2 roofs do not connect nicely (look at is attached model).
    So I still think making the roof out of a few pieces makes it much easier and gives you more control.
ID:	17228   Click image for larger version.
    May 1, 2014
    03:04 PM
    Thanks for the help do you have any chance still have the roof file I can use. So i can see how its done, at school we only learned how to make 1 roof
    1,628
    05:04 PM
    I can send it to you, but it would be in Revit 2014, so if thats no problem let me know
    [edit]
    here you go
    https://www.dropbox.com/s/fwcc3mr503...ign_VH8901.rvt
  1. New rig for Revit and working with pointclouds
    By RonaldHulsegge in forum Hardware and Infrastructure
    Last Post: October 6th, 2013, 06:23 AM
  2. Issues with working on a shared central file whilst working remotely.
    By mhug9 in forum Architecture and General Revit Questions
    Last Post: June 25th, 2013, 11:49 PM
  3. How to Remove Working Views from your Revit Project with Python Shell
    By dp stuff in forum Third party Add-Ins, API and R&D
    Last Post: March 22nd, 2013, 05:23 PM
  4. Working with IFC files in Revit
    By mpc462 in forum MEP - General
    Last Post: February 21st, 2012, 09:16 PM
  5. AnnoFamily working ok in FamEditor and wrong in Project
    By gaby424 in forum Architecture - Family Creation
    Last Post: October 13th, 2011, 05:25 PM
