Thread: Rotate Callout View
    "OMG I killed Revit"
    dzatto's Avatar
    5,245
    05:51 AM
    Rotate Callout View
    Is there any way to rotate my callout view, with rotating the model or the callout itself?
    Basically, I have a callout around my pit openings. They are going north south, but, on my callout view, I put them east west because they are long and they fit on the sheet better that way.
    OR, do I leave the view as is and annotate it, then rotate the view in the sheet instead?
    Kingdom of Denmark
    4,267
    12:51 PM
    Edit: Should have read the entire post... You can also rotate the Callout View it self. Select the Crop Region on the Callout View, and use the rotate tool.
    Alex Cunningham's Avatar
    Northern California
    3,576
    03:51 AM
    Now all I want is the ability to make non rectangular callouts.
    St. Louis, MO
    1,961
    05:51 AM
    Yep--ditto that.
    ...and on a related subject, a somewhat overlooked or unknown thing about sections is that you can rotate them as well to create "Plan Views"--place a section mark vertically, then rotate, and voila--a new "plan view"--good way to generate special views where you don't need or want a Level or Plan Region.............however, use with discretion.
    dzatto's Avatar
    5,245
    05:51 AM
    Well I'm stupid. I did that and noticed the callout itself rotated on the plan, so I undid it. I didn't even think to resize the callout after I rotated it.
  1. Rotate plywood hatch?
    Last Post: October 4th, 2018, 07:28 PM
  2. rotate painted pattern
    Last Post: June 1st, 2011, 02:36 PM
  3. Detail Callout Modifications
    Last Post: April 1st, 2011, 06:39 PM
  4. Rotate Sun's North
    By dzatto in forum Rendering and Gallery
    Last Post: March 12th, 2011, 10:20 AM
