Results 1 to 10 of 18
Thread: Angled array nested into roof truss family
    February 8, 2013
    31
    01:05 AM
    Hi All,
    I really need some help with a family that I've created. It's essentially a pitched roof timber truss. I've nested some families into it which are the bracing gussets fixed to the sides of the timber members. I can get these to change angle with the truss nicely when the pitch is altered. However these bracing gussets need to be a set distance from each end and then be at a min/max of 600mm centres. I cannot achieve the minimum spacing, and it struggles when rotate the truss after I've put a dimension paramter for the offset at each ends. I need to somehow make this dimension link to a ref line or plane that rotates, as the dimension no longer is parallel to the rotated component.
    Cheers
    Moderator mark b's Avatar
    NSW Australia
    1,436
    11:05 AM
    Would like to post the truss family it will go a long way in being able to help you.
    February 8, 2013
    31
    01:05 AM
    Thanks. Have managed to sort this out shortly after you posted your reply! That always seems to be the way, hence I quite often battle it out by myself to get things resolved.
    I have another problem with a structural column family which has been made into a timber frame column. I need to be able assign paramters to the overall height of the column. These heights also need to schedulable, of which I have shared parameters to do so. But the main issue is that if the height is controlled by the upper level (which is ideal for some columns - not all, as some will continue up to eaves level, but some will just be small infill panels and will want to be controlled with intance dimensions, to get round this I may create two different families) and I cannot see a way to run parameters off the top level value. Is this possible? For example I have an array which the quantity of items is updated depending on the height of the column. I have done this with a dimension but the whole family does not link with the upper level.
    February 8, 2013
    31
    01:05 AM
    Also, if I try to align the family within a project to a level it does nothing. The height is only controlled through the properties.
    3,231
    09:05 PM
    I agree with Mark B., above. Please post some images of what you're dealing with. It's so much easier for us to provide some help if you post some illustrations or a family, instead of writing paragraphs with descriptions.
    February 8, 2013
    31
    01:05 AM
    OK thanks.
    See image below:
Name:	Wall Panel.JPG
    February 8, 2013
    31
    01:05 AM
    Going back to the roof trusses. I have the family working perfectly in family edit mode, but when it is loaded into a project is doesn't work properly (the bracing gussets go off) when changing the angles as can be seen in the images attached. Why is this? All things fine until loaded into a project?! Something simple I've missed off I'm assuming?!
Name:	Roof panel family - 35deg.JPG
ID:	17791Click image for larger version.
Name:	Roof panel family - 45deg.JPG
ID:	17792Click image for larger version.
Name:	Roof panel family in project 35 and 45 deg.JPG
    3,231
    09:05 PM
    Well, now you have two different questions in the same thread. Maybe it would be better to start a new thread for the other question.
    Anyway, about the original question: make the array in one family, make that family workplane based, and nest it into the other family; set its workplane to a reference line that is controlled by an angular dimension. About the spacing, make the number of items be controlled by the value of the spacing.
    About the other question, yes, it is possible to measure from the top level going down, in the structural column template. You can use a reporting parameter to schedule those distances.
    February 8, 2013
    31
    01:05 AM
    OK thanks Alfredo.
    So to make the first family workplane based, how do I do that? At the moment the workplane box value is grey and displays: Level: Ref;level with no grey box to the right to adapt. If this is all normal, then how do I set the nested familys workplane to a reference line?
    3,231
    09:05 PM
    In the family, on the ribbon, under the Modify tab, find "Category and Parameters". Set "Work Plane-Based" on and "Always vertical" off. Then, when the work plane-based family is loaded into another one, the placement option should be by "workplane". Then, you place and rotate the nested family so that its rotation matches the rotation of the reference line that is controlled by an angular dimension, and then you select the nested element and click on "Edit Workplane", and select the reference line.
  1. Help with Barrel Shaped Roof with Angled Walls
    By melloblkmon in forum Architecture and General Revit Questions
    Last Post: November 15th, 2013, 02:12 PM
  2. Roof truss calculations
    By philj in forum Architecture and General Revit Questions
    Last Post: September 10th, 2012, 08:02 AM
  3. Array nested voids in a family
    Last Post: May 25th, 2012, 02:10 AM
  4. Roof truss dxf export problem
    By mEANm in forum Architecture and General Revit Questions
    Last Post: April 24th, 2012, 07:48 AM
  5. Adaptive Family - Angled Extrusion
    By devinmccarthy in forum Architecture - Family Creation
    Last Post: January 24th, 2012, 03:25 PM
