Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Topography visibility in plan views
  1. #11
    2,794
    04:08 PM
    Quote Originally Posted by mona miller View Post
    Yes, you are absolutely right! I had to put point below cut plain in order to see cut pattern in my view!
    And now occur new problem that I already has constantly: maybe someone come up with a solution:
    I have pads on different levels (see pic). On my basement plan on the place of upper pads I see gap in earth cut pattern. I noticed this is happening all the time when the pad is above view plan! Any idea how o fix it without using Filled Region?
    pic:
    https://dl.dropboxusercontent.com/u/72146861/pads1.jpg
    https://dl.dropboxusercontent.com/u/72146861/pads2.jpg
    set your view region to cut the main pad, then use a plan region to set the view region for the other one.
  2. #12
    2,794
    04:08 PM
    Quote Originally Posted by Andre Carvalho View Post
    ...I think the OP is talking about the earth pattern. My findings is that it works, but only when at least one of the topography points are below the view region cut plane...
    5 years later and I'm relearning again and as Andre says, at least 1 point needs to be below the cut plane.
    On a commercial tower I'm currently working on I've been struggling to get the cut pattern of the topo to show on the basement plans, so I moved a single topo point down to -20000mm (lower than my lowest basement and at a place that is well off to the side of the site to so it doesn't affect anything else).
    Cut pattern shows as it should now.
  3. #13
    July 24, 2019
    07:08 AM
    similar situation here but can't add a point because its within another topo surface region so can't be fudged.
  4.    #14
    June 17, 2020
    06:08 AM
    pic:
    How did you get to solve this? Please help!
  1. Topography Surface: Visibility Graphics + Section Cut question (Revit 2011)
    By itchiamg in forum Architecture and General Revit Questions
    Last Post: August 29th, 2017, 12:19 PM
  2. Site topography visibility in 3D view
    Last Post: September 11th, 2013, 10:40 PM
  3. Rotate plan views not the views on the sheets
    By jh75 in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 09:36 AM
  4. What Revit Wants: Topography edge visibility workaround
    Last Post: March 8th, 2012, 04:15 AM
  5. Column visibility in plan view (totally same columns, different views)
    Last Post: May 27th, 2011, 08:34 AM
