Results 1 to 10 of 14
Thread: Topography visibility in plan views
    Member mona miller's Avatar
    July 31, 2013
    185
    04:29 AM
    I have underground basement level. How to make visible topography on my basement plan, so I can see the cut earth around my basement walls?
    The topography is checked in V/G! Don't know what am I doing wrong?
    2,794
    02:29 PM
    Quote Originally Posted by mona miller View Post
    Adjust your view range higher so the topography is within your view range. The edit... button next to the view range parameter in the properties browser. However, topography doesn't have any thickness so I'm almost certain you won't see a cut surface like you do in elevation, so you may need to override the topography surface pattern to show your earth pattern, easily done with VG's or a view filter.
    May 20, 2011
    Chicago, IL
    814
    11:29 PM
    I don't think that can be done other than with filled region.
    July 31, 2013
    185
    04:29 AM
    In my previous project, I could make this without problem (see the link: https://dl.dropboxusercontent.com/u/...topography.jpg)
    On my current project can't accomplish same thing although I am doing exactly the same steps and procedure.
    Don't know why...
    May 20, 2011
    Chicago, IL
    814
    11:29 PM
    Aha, so you’re talking about contour lines, not cut earth pattern that you see in section or elevation views.
    Go to VV expand Topography and make sure primary and secondary contours subcategories are checked along with topo category.
    Revit Maestro Andre Carvalho's Avatar
    Toronto
    47
    12:29 AM
    No PijPiwo, I think the OP is talking about the earth pattern. My findings is that it works, but only when at least one of the topography points are below the view region cut plane. If the OP has a flat site and doesn't care about the shape of the topography she can add an extra topography point away from the others defining the site and then just crop the view. Makes sense?
    May 20, 2011
    Chicago, IL
    814
    11:29 PM
    Quote Originally Posted by Andre Carvalho View Post
    It could be.
    Yes, this is correct, but I'm still confused about OP question. Some pics will help.
    December 20, 2010
    singapore
    91
    04:29 AM
    Screenshot would be helpful.
    My assumption would be that the material isn't set in the massing/site properties so that's why the cut pattern isn't showing up.
    2,794
    02:29 PM
    As darryl added, you need to set the material in the massing site/properties dialogue. Whatever material you assign here must have a cut pattern assigned to it.
    After actually checking in Revit (lol), it seems what I said earlier is both correct and incorrect, you do need to adjust the view range and you also get to see cut topo surface patterns in plan views. In these images the topo low points are at -2000 and the high points are are +1000, and see the view range settings.
    standard 3d view
    view cube > orient to view > plan...(then rotate view for this pic)
    plan view
    July 31, 2013
    185
    04:29 AM
    Yes, you are absolutely right! I had to put point below cut plain in order to see cut pattern in my view!
    And now occur new problem that I already has constantly: maybe someone come up with a solution:
    I have pads on different levels (see pic). On my basement plan on the place of upper pads I see gap in earth cut pattern. I noticed this is happening all the time when the pad is above view plan! Any idea how o fix it without using Filled Region?
    pic:
    https://dl.dropboxusercontent.com/u/72146861/pads1.jpg
    https://dl.dropboxusercontent.com/u/72146861/pads2.jpg
  1. Topography Surface: Visibility Graphics + Section Cut question (Revit 2011)
    By itchiamg in forum Architecture and General Revit Questions
    Last Post: August 29th, 2017, 12:19 PM
  2. Site topography visibility in 3D view
    Last Post: September 11th, 2013, 10:40 PM
  3. Rotate plan views not the views on the sheets
    By jh75 in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 09:36 AM
  4. What Revit Wants: Topography edge visibility workaround
    Last Post: March 8th, 2012, 04:15 AM
  5. Column visibility in plan view (totally same columns, different views)
    Last Post: May 27th, 2011, 08:34 AM
