Results 1 to 10 of 13
Thread: Residential Windows
    6,387
    05:14 AM
    Residential Windows
    I'm trying to rework and simplify my window library and for some reason it is kicking my ass. I'm entirely certain that I am over thinking the entire process but thought I should at least see what's out there.
    First (I'm a mooch) - does anyone have a window (double / single hung preferably) they would care to share? I don't need or want an entire library, just one to pick apart & reverse engineer. If you do post an entire library you are awesome (I'll rebuild mine either way though.) I know several of the manufacturers have families but I don't like them for any number of reasons.
    I don't think it is the best approach but in terms of process here is what I have been doing:
    The bulk of our work is design-build of some variety and a lot of details such as the exact frame size are never really addressed, I'm building with that in mind. This also assumes a double / single hung window since it is the most common type that is used here.
    1. Get CAD details from a manufacturer. For all intents and purposes I'm viewing them as the same and the manufacturer will be dealt with in a spec or note rather than build a library for each manufacturer.
    2. Take details and clean them up so they are usable dimensionally (mostly to keep me sane) - this does mean some minor size adjustments, i.e. going from 17/32" to 1/2" - I'm ok with them up to 1/8" tolerance.
    3. Create profiles from details as needed
    4. Create the Frame, Upper Sash, Lower Sash (GM, converted to window category)
    5. Nest all 3 into a window host (this is actually several steps and results in a lot of formulas in the family that carry through to the model)
    6. Add in a Sill & Head (two separate families)
    7. Lots of formulas and parameters to get everything to flex correctly.
    What I'm thinking of doing: (first 3 are the same)
    4. Create the upper & lower sash as one family
    5. Create the frame
    6. Nest the sash into the frame - my thought on doing it this way is just to keep constraints simpler and keep the bulk of the formulas out of sight.
    7. Nest that entire assembly and my Head & Sill into a host family to go into the model. Use this family to control location in the wall, double / triple assemblies with vertical mullions, etc
    8. Create use based families similar to Aaron's doors - Window-Casement, Window-Double-Hung, Window-Fixed-Pair and then use parameters to drive the various bits and pieces.
    In theory that will make the family in the model a lot easier to use so I don't have to wade through a gazillion parameters just to change the width of the entire unit.
    Am I on the right track with that thought process?
    What level of detail should the profiles be taken to? The manufacturer profiles are overly intricate and (IMO) don't display well, especially when you get down to the small curves without some editing.
ID:	18071   Click image for larger version.
    11,164
    04:14 AM
    Theyre more complicated than the doors, but there is good reason. Dont have time to do a large type up right now, but will try to revisit later.
    6,387
    05:14 AM
    There more complicated than the doors, but there is good reason. Dont have time to do a large type up right now, but will try to revisit later.
    The complexity has to do with the masonry trim per Mia's talk at RTC correct? That aside they are way simpler than what I've been doing...
    And thanks!
    11,164
    04:14 AM
    Yes and no. They get more complex as you start to flex the dimensions... Because the nested families need to drive one anothers dimensions, which you obviously cant do. So there are times you need to edit a Type property of the shared nested window, and then edit a type or instance property of the Parent window itself. But to build the windows correctly to represent the Panning, its the only decent way to achieve it.
    And yes, Mia went over this in *our* lecture. (She taught it in Chicago, i taught it in Australia, lol)...
    6,387
    05:14 AM
    Yes and no. They get more complex as you start to flex the dimensions... Because the nested families need to drive one anothers dimensions, which you obviously can't do. So there are times you need to edit a Type property of the shared nested window, and then edit a type or instance property of the Parent window itself. But to build the windows correctly to represent the Panning, its the only decent way to achieve it.
    Hm. I'll look more into the flexing side of things in a bit. The geometry itself is a lot simpler than what I've been doing though which is good. Cleaning up and recreating the manufacturer profiles takes for ever...
    Shows what I know It was a good class at least
    11,164
    04:14 AM
    The geometry isnt the hard part. I dont remember if the F00-Panning frame is already loaded in that Family that i sent. If not, its the nested frame where you will start to see the issues. The nested Frame profiles cant realistically be parametrically tied to the parent family, since the Panning profiles of the windows is far more complex than Door Frames. But that Parent windows sizing MINUS the Frame panning needs to drive the Actual Window Panel itself (the not-really-architecturally-present-but-nested-family i use for swapping window actions). So you just end up with redundant parameters. No way around it.
    6,387
    05:14 AM
    For reference - here is a window I'm using at the moment.
    6,387
    05:14 AM
    Question - when you have a window unit with a transom, which is technically 2 windows - do you create a new type so you can nest your trim or is the trim then applied separately in the project?
    11,164
    04:14 AM
    If its a real transom (one larger hole in the wall), id do it as a new Parent Family, with nested trim, another nested intermediate trim, and the "panel" families.
    But ive seen some residential projects where the "transom" is a whole other window, and there is even exterior finish between them, like a soldier course of brick. In that case... different families all together.
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    477
    07:14 PM
    I think that would be challenging in an office environment of mixed skill levels.
    Is this work methodology still the case with v2017/v2018? I don't believe we can drive the nested shared parameters.
  1. Load Demand Calculations for Residential
    By sethridge in forum MEP - General
    Last Post: March 27th, 2014, 07:56 PM
  2. Residential Wood Framing and Take Offs
    By Xelcho in forum Architecture and General Revit Questions
    Last Post: October 29th, 2013, 04:36 PM
  3. Residential Renovations Workflow
    By JCM in forum Architecture and General Revit Questions
    Last Post: October 17th, 2013, 09:14 PM
  4. Residential structure - worth it?
    By kowen1208 in forum Structure - General Questions
    Last Post: July 23rd, 2013, 06:39 PM
  5. Revit Champion - Residential Needed - OKC
    By jgfry in forum Career Corner
    Last Post: June 14th, 2013, 04:35 PM
