Thread: I can't get objects behind glass to export to a dwg file
    April 26, 2014
    04:05 AM
    I'm trying to export an elevation view to a dwg file but when I open the dwg file in autocad none of the objects behind glass are visible. In my Revit file I have the glass transparency on my windows and curtain wall panels turned to 100% so in my Revit view all of the objects behind the windows are visable but when I open the exported dwg file only the exterior of my view is visible.
    I checked my visibiliy graphics to make sure everything was turned on but I'm new to Revit so aside from that I'm not sure of what to adjust.
    Any advice would be greatly appreciated
ID:	18114   Click image for larger version.
Name:	exported dwg file.jpg
    Moderator Drew's Avatar
    Perth, Western Australia
    691
    04:05 PM
    It is expected behaviour. Yes, the "glass" seems transparent in the revit file, however when exported, it is the extent of the glass face that is replicated, but treated as a solid ie no transparent material applied.
  1. Export to DWF file Size
    By sternjohn662200 in forum Architecture and General Revit Questions
    Last Post: December 30th, 2013, 01:52 PM
  2. Lost dwg export file
    Last Post: November 15th, 2012, 12:50 PM
  3. Problem in dwg file import Revit then export gbXML file
    By roczhu in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2012, 11:47 AM
  4. Export ACA Objects - Revit.ini
    Last Post: April 20th, 2012, 01:29 PM
