Results 1 to 10 of 12
Thread: Roof surface pattern, where i can change line weight?
    Member bangobeat's Avatar
    April 14, 2011
    263
    08:23 AM
    Every pattern I override in elevation - expresses in fat line weight. Where i can change it?
    thanks
    Moderator mark b's Avatar
    NSW Australia
    1,432
    05:23 PM
    Surface pattern line weigths are hard wired, best you can do is lighten off the colour maybe to a grey.
    or
    you can do some intense reading and rewrite your line weight defaults.
    June 3, 2011
    PA, USA
    120
    02:23 AM
    Mine don't do that, but I don't remember how I got them to look the way that I wanted. I think they are wired to lineweight 1 and I changed all my weights down proportionally to work at the scales I normally work at. My line weight 1 is set to .0015 at 1/4 and smaller
    April 14, 2011
    263
    08:23 AM
    How you manage then in elevations views? Or you use some kind of other trick? I wanted to show vertical surface pattern for roof, but unfortunately its showing 5 line weight. Graphically its not a great choice? or you think its alright?
    June 3, 2011
    PA, USA
    120
    02:23 AM
    Are you using model pattern or drafting?
    April 14, 2011
    263
    08:23 AM
    Its impossible to use model patterns.. probably
    June 3, 2011
    PA, USA
    120
    02:23 AM
    You are trying to override your pattern by view, which will only allow drafting patterns. You must use model patterns in the element materials and not override them in the view. So you need to assign a material to the top layer of your roof and give that material a model pattern.
    2,695
    04:23 PM
    Quote Originally Posted by bangobeat View Post
    It is possible to import(or create new from existing) patterns at custom scales...which may make different lineweights?
    Member Ben-May's Avatar
    Melbourne,Oz
    305
    05:23 PM
    Surface patterns will follow the object-style pen weight for the projection line for each category, so lighten your object style for projection lines>roofs
    April 14, 2011
    263
    08:23 AM
    Ben-May thanks, thats the answer that i was looking for.. Completely forgot about object styles. Respect
  1. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 01:14 AM
  2. Surface Pattern for Topography
    By JCM in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2012, 04:10 AM
  3. Family Surface Pattern Thickness
    By W.Neuok in forum MEP - General
    Last Post: June 1st, 2011, 09:02 PM
  4. Drafting Cut Pattern Line Weights on Walls
    Last Post: May 2nd, 2011, 09:42 PM
  5. Change of Pace
    By Dive_Syko in forum Out There
    Last Post: February 2nd, 2011, 09:40 PM
