Thread: Roof cut
    May 30, 2011
    14
    07:14 AM
    Roof cut
    Is it possible to cut a section from a roof as shown in the image? I want to omit the red section.
    Thanks
    March 5, 2011
    Southern California
    666
    10:14 PM
    yes, model and in-place family void, roof category, and then use cut geometry to cut the void from the roof.
    May 30, 2011
    14
    07:14 AM
    Thanks Scott, works perfect.
    Procedure for those who are unaware...
    Home/Component [dropdown]/Model In-Place
    Family and Parameters/Family Category - select roofs or whichever type requires a cut
    Provide a name for the void
    Select Extrusion or alternative from Forms
    Draw profile for the extrusion and provide Depth value
    Properties for the extrusion, Identity Data select Void
    Use Cut Geometry tool to cut the void
    Moderator mark b's Avatar
    NSW Australia
    1,432
    05:14 PM
    You could use Vertical Opening on Home Tab. Same result and a lot quicker
    Kingdom of Denmark
    4,262
    07:14 AM
    Looking at the OP image, Id say that it could even be achieved by setting the "Rafter Cut" and "Facia Depth" of the Roof to the right values...
    March 5, 2011
    Southern California
    666
    10:14 PM
    Good point! I forgot about that tool...
  1. Square Cut Fascia
    Last Post: April 25th, 2014, 12:02 AM
  2. How to Roof Merge/Join to Lower Roof!!
    By crhdesign in forum Architecture and General Revit Questions
    Last Post: April 30th, 2011, 06:48 AM
  3. How to hide cut profile cut lines
    Last Post: April 28th, 2011, 12:58 PM
  4. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 01:47 PM
  5. Window Cut Plane
    Last Post: January 13th, 2011, 08:08 PM
