Thread: Error in RAC2011, any suggestions? project file attached
    Member bangobeat's Avatar
    April 14, 2011
    263
    07:13 AM
    Go to the section and try to dimension column! it crashes.. any suggestions?
    Melbourne, Australia
    1,145
    03:13 PM
    No crashes here - was able to dimension height of column. Try deleting the section and creating a new one.
    Nantes, France
    1,381
    07:13 AM
    I've open the file in RST 2012, no crash; but what is weird is that i can dim the height of the column but not the width in cut view.
    you have to be carefull with rotated objects when making cut views, you'll be able to dimension only if the view is perpendicular to faces.
    I use personally a ref plane to be perpendicular to faces then snap my cut view to this plane.
    works fine for instance in elevation view. bug are you here???
    Moderator Drew's Avatar
    Perth, Western Australia
    691
    01:13 PM
    I have had this issue with elements not being perfectly square to the view plane. I ma not at my PC right now but if you check I think you might find the column is slightly rotated from the view plane.
    April 14, 2011
    263
    07:13 AM
    Actually it was rotated 0.018 degrees, thats why it made errors
  1. Transfer Project Standards error - any ideas?
    By Darryl_S in forum Architecture and General Revit Questions
    Last Post: June 5th, 2015, 11:36 AM
  2. Leader attached to callout head
    Last Post: May 20th, 2011, 04:07 PM
  3. Forum suggestions
    By mark b in forum Forum Suggestions and Feedback
    Last Post: January 12th, 2011, 09:38 PM
  4. Multi Revit File Project
    By Chowdur in forum Architecture and General Revit Questions
    Last Post: December 15th, 2010, 05:13 PM
