Results 1 to 10 of 13
Thread: Inconsistent Units in Yes/No Parameter if/and Statement
    December 1, 2014
    01:37 AM
    So I have what should be a simple if/and conditional statement that I'm using to drive a Yes/No parameter in my L-shaped countertop family. The family contains instance parameters to control an angled corner, and rounded edges.
    My statement is as follows: = if (and (corner angle, left radius), 1, 0)
    where "corner angle" and "left radius" are both instance yes/no parameters.
    However Revit rewards me with the dreaded "inconsistent units" error. Can anyone explain why this might be happening?
Name:	countertop statement screenshot.PNG
    May 20, 2011
    Chicago, IL
    795
    12:37 AM
    This might help.
    3,031
    09:37 PM
    Revit doesn't accept 1 or 0 as a value for a yes/no parameter.
    You could write the formula like this instead:
    not(and(corner angle,left radius))
    In plain english the formula reads, "This parameter is not checked only when corner angle AND left radius are."
    In contrast:
    In plain english the formula reads, "This parameter is checked only when corner angle AND left radius are."
    Last edited by Steve_Stafford; December 1st, 2014 at 09:06 PM. Reason: restated the logic
    2,668
    10:37 PM
    But it accepts 1=1 and 1=2 (or their equivalents) for Yes and No respectively.
    3,031
    09:37 PM
    What Greg is suggesting is that you can keep your formula but written like this instead:
    if (and (corner angle, left radius), 1=1, 1=2)
    Instead of just using 1 or 0, providing a switch value, let Revit evaluate the true/false result as a math problem to solve. 1 is equal to 1, that's true. 1 is not equal to 2, that's false. Make sense?
    December 1, 2014
    01:37 AM
    Excellent. I tried both solutions and they both work as you have described. I like the simplicity of the "and(left radius, corner angle)" formula, but it's nice to know that I wasn't too far off track with my original concept.
    Thanks for the help.
    July 27, 2012
    singapore
    14
    01:37 PM
    Hi all,
    I tried to create visibility for void using if then statement , but the inconsistent unit is killing me,
    needed help , i not sure where it goes wrong ?
    Thank in advance guy !
Name:	void visibility.jpg
ID:	26152Click image for larger version.
    2,668
    10:37 PM
    I see 2 errors; replace 1, and 0 with 1=1, and 1=2 (assuming you meant for 1 to equal true/on and 0 to equal false/off), and remove "Void_L ="
    Member ScubaMan's Avatar
    July 7, 2015
    203
    10:37 PM
    I did not know you could use 1=1 and 1=2. I have always done 1<2 and 1>2. Same difference i guess.
    Thanks for the info guys,
    July 27, 2012
    singapore
    14
    01:37 PM
ID:	26170Click image for larger version.
    hi Greg,
    I end up created another parameter by tying Void=L another ref. plane in order for "Void=L" to function with length
    1) Void Extrusion don't have a visibility on/off check box
    I tried IF ( AND (x = 1 , y = 2), <true>, <false>)
    Returns <true> if both x=1 and y=2, else <false>
    but still not able to make it ... can show how to write the 1=1 and 1=2 formula ?
    thankss
  1. Revit - Inconsistent Units and how to neutralize them.
    Last Post: July 12th, 2019, 03:07 AM
  2. Yes/No Parameter in Conditional Statement
    By keithwales in forum Architecture and General Revit Questions
    Last Post: September 16th, 2014, 06:00 PM
  3. Replies: 12
    Last Post: June 4th, 2013, 08:08 PM
  4. Yes/No type parameter with if statement, help
    By srsatdmi in forum Architecture - Family Creation
    Last Post: December 5th, 2012, 04:10 PM
