Thread: Structural Framing members under (hidden) not showing hidden
    November 11, 2014
    7
    07:06 AM
    I got some floor beams supporting the floor slab but when you look at the plan view the beams shown as continuous even though they are under the slab. This happens in Course view only (It shows dash in medium and fine view). Do anybody knows is there any settings where we can change the presentation of members under to hidden in Course view.
    Thanks
    May 20, 2011
    Chicago, IL
    814
    04:36 PM
    Try this: in the ‘object style’ window, expand ‘structural framing’ and change the line pattern for ‘other’ subcategory.
    November 11, 2014
    7
    07:06 AM
    Quote Originally Posted by PijPiwo View Post
    Try this: in the object style window, expand structural framing and change the line pattern for other subcategory.
    Thanks for your reply,
    Changing the object style of `other' (structural usage) subcategory will change all over the drawing. What my problem is this beams under floor are with `Girder' structural usage and in some cases they are partially under the slab. It works fine in MEDIUM & FINE view where true object is presented but in Course view where I got single line presentations it does not work.
    Thanks
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    303
    04:36 PM
    What is the material of the beam supporting the slab? Concrete or steel? Typically, a steel beam will display continuous, and the line weight will change when the usage is set to girder or joist or other. If it's a concrete beam and the lines are not hidden, you may want to try editing the beam family and verify the "Display in Hidden Views" setting.
    November 11, 2014
    7
    07:06 AM
    Quote Originally Posted by Knitro87 View Post
    It is Steel Beam. Is there anything can be done in Structural framing family.
    Thanks
  1. Hidden line view. Hidden lines showing.
    Last Post: July 27th, 2013, 09:12 AM
  2. Make walls down below hidden on Framing Plans
    By tlcp_rsmith3040 in forum Structure - General Questions
    Last Post: February 25th, 2013, 10:57 PM
  3. Show hidden framing lines in elevation?
    By Defiant1 in forum Structure - General Questions
    Last Post: December 17th, 2012, 03:28 AM
  4. Piles not showing hidden lines through structural foundations
    By edmund in forum Structure - General Questions
    Last Post: June 26th, 2012, 09:13 AM
