Thread: Disappearing Fittings
    March 24, 2014
    10:07 AM
    So, when I select certain fittings and draw a vertical pipe, the fitting disappears after I select Apply. You can see in the image, the pipe with the Elbow with no riser. The two pipe that you see next to it that are not connected is what happens when I try to draw a vertical pipe from an Elbow. Things like this happen with other fittings as well. I downloaded the fittings from the Charlotte website. Maybe I installed them wrong?Click image for larger version.
    3,125
    09:07 AM
    It wouldn't be the first Charlotte fitting I've seen that didn't work as expected.
    Can an you post it here with its lookup file?
    March 24, 2014
    10:07 AM
    I am using Revit MEP 2012. I fixed the problem with the 90 Bend. I'm not sure if it was the routing option, or un-checking the ALWAYS VERTICAL box in the Family Category & Parameters, but I got it to work. I have even messed around with the lookup tables on a few fittings to get some different sizes that I needed, but I still feel lost. Some fittings I am not able to make work. I have attached one in particular. It is a Two-way clean out that should have 2 size options, but I can only get the 3" to work, not the 4". There are other fittings that have the same problem. The smallest nominal size will work, but when I try to change it to another size, I get the message:"Can't make type "Pipe-Fitting_Two-Way-Cleanout_ABS-DWV_448_Charlotte : Standard". If anyone knows how to fix the attached fitting and can explain how they did it, whether in the Lookup Table or the Formula, it would be much appreciated.
    P.S. A little about myself: I was a journeyman Plumber who went to school at night to learn drafting/design. I was mostly taught using AutoCAD, but did get to experiment with Revit & Inventor. Revit is an amazing Tool, but if I can't plumb the same way I would in real life, then it does me no good.Pipe-Fitting_Two-Way-Cleanout_ABS-DWV_448_Charlotte.rfaABS-448.csv
  1. Pipe Fittings disappearing...
    Last Post: November 4th, 2013, 07:43 AM
  2. disappearing level
    By pbergerd in forum Architecture and General Revit Questions
    Last Post: December 14th, 2012, 04:45 PM
  3. Disappearing Family?
    By RsqPrincess in forum Architecture and General Revit Questions
    Last Post: December 13th, 2012, 07:10 PM
  4. Disappearing Dimensions
    Last Post: September 16th, 2012, 11:51 AM
  5. Why do my pipes keep disappearing?
    By Kbreedon in forum MEP - General
    Last Post: August 4th, 2011, 12:24 AM
