Thread: Cannot repeat adaptive component
    May 11, 2012
    30
    12:37 PM
    Hey,
    I am having trouble repeating this component, I think it has to do with the divided surfaces being drawn on different work planes.
    Is there another way to draw this? I have tried many times now, with no success. What is important is that the whole form is within 1200mm x 2200mm x 3300mm.
    Thank you.
    Attached revit 2015 file.
Name:	Screen Shot 2014-12-11 at 3.06.21 PM.png
    August 12, 2011
    80
    12:37 PM
    I cannot open your file ( I use 2014) but I did something like that, and realized that the second form frame must to be copied from the first one then to be ceated form and changed afterward .
    October 7, 2018
    12:37 PM
Name:	2019-4-12 16-44-54.png
ID:	36423   Click image for larger version.
Name:	2019-4-12 16-45-25.png
    3,228
    08:37 AM
    What is the purpose of the repetition? Seems that you already have a form.
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    338
    01:37 PM
    User sxr had the answer. One of your surfaces has another direction. Try rotating the pattern 180deg, that'll work
    Sendt fra min ONEPLUS A5000 med Tapatalk
  1. About Adaptive Component
    By thaihoalu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: December 10th, 2014, 03:17 AM
    Last Post: March 14th, 2013, 07:15 AM
    Last Post: October 15th, 2012, 09:45 PM
  4. Proiblem with Adaptive component
    Last Post: July 28th, 2012, 03:43 AM
  5. Adaptive Component Help
    By djnelson75 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 3rd, 2011, 07:23 PM
