Thread: Filled Regions in family appear on top of Lines when loaded in Project
    Member kescr's Avatar
    June 2, 2014
    53
    01:03 AM
    I'm trying to create some Break Lines with a filled region between the two (to demonstrate a break between very long site sections).
    When I draw the Filled Region in the family editor, it automatically applies itself to the background. When the family is loaded into the project, the Filled Region moves itself to the front! I can't seem to find the Send to Back and Send to Front buttons when I select the filled region or lines.
Name:	Cut line 1.PNG
ID:	20498   Click image for larger version.
Name:	Cut line 2.PNG
ID:	20499   Click image for larger version.
Name:	Cut line 3.PNG
    2,774
    01:03 AM
    Can't tell how you built it but one way is to change the edges of the filled/masking region to a non-invisible line style. I think there's a Revit OTB family for these already but I'll attach one we use anyway.
    June 2, 2014
    53
    01:03 AM
    That is a very clever workaround! Thank you so much for the help
  1. Filled regions in detail component masked by model elements in family
    By john.warburton in forum Architecture and General Revit Questions
    Last Post: October 21st, 2015, 03:38 AM
  2. No windows family is loaded in the project - New Revit user
    By Jeff Jefferson in forum Structure - General Questions
    Last Post: October 1st, 2014, 10:27 PM
  3. Parts of family offsetting when loaded into project
    By dirtychinchilla in forum MEP - General
    Last Post: September 23rd, 2014, 03:16 PM
    Last Post: December 20th, 2011, 11:15 PM
