Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Revit Cannot Import Sketchup file
  1. #21
    10,889
    02:00 AM
    Marcy, dont take this the wrong way... But your question doesnt make much sense at all.
    Sketchbook is a drawing program, for "sketching" on a tablet or computer.
    Sketchup is a conceptual modeling tool (and in my humble opinion, a lousy one).
    What "compatibility" are you talking about, with either? Ive used/use all three, but i cant see what you are getting at.
  2. #22
    Member BD Mackey's Avatar
    November 1, 2013
    480
    01:00 AM
    As Aaron mentioned they really aren't comparable, if you are looking for an Autodesk program that is comparable to Sketchup then you need to look at Formit
  3. #23
    New Member Plans by Marcy's Avatar
    June 3, 2016
    03:00 AM
    Hello Twiceroadsfool,
    Thank you for getting back with me. I started using Revit about 1 1/2 years ago, so the program (given it's size & complexity) is relatively new to me. While watching some Revit tutorials, I saw the sketchbook (autodesk product) vs sketchup (google product) and was wondering if drawings generated from either/or could be loaded into Revit.
    Since my laptop doesn't have enough oomph to handle Revit. I was thinking I could download my job site notes into Revit from a sketching program and keep on keeping on once I got home without having to start from scratch, plugging in handwritten notes.
    The Sketch-up program looks easy enough to use. I did not look into Sketchbook any further than comparing prices, since I though it might be wise to ask someone familiar with the programs before I spent to much valuable time on something that may not prove useful. Thus my reason for asking about 'compatibility' with Revit.
    It appears that Sketchbook is considerably more expensive than Sketch-up. I was thinking the two programs were basically similar with the exception of manufacturers and perhaps the ability to use them with other programs. Thanks for the clarification between the two programs. I just joined this forum, so for some reason your message was in my spam box, thus the delay in response.
    Rest assured, your advice IS APPRECIATED. Take Care, Marcy
  4. #24
    April 2, 2014
    02:00 AM
    Converting to Sketchup 7 did the trick, I was able to import it.
    Yes, Sketchup is a terrible piece of software. However, our office used it for conceptual modelling, so I had to use it to "trace" my real Revit model on top of it. I can't wait to dump the Sketchup and obviously, the users should stop using Sketchup ASAP and use Formit.
    In the meantime, importing a Sketchup model is a blessing.
  5. #25
    Member J.Merlan's Avatar
    August 19, 2016
    55
    12:00 AM
    Quote Originally Posted by samuelab View Post
    Thanks for posting an actual answer to this thread. It helped me out a lot today!
  6. #26
    March 26, 2018
    12:00 AM
    I figured it out.
    In your sketchup file-
    Save as - Save as type: Sketchup Version 3
    It's not perfect but should work.
  7. #27
    Member truevis's Avatar
    January 7, 2011
    112
    03:00 AM
    Revit can import SketchUp up to version 8. Exporting only faces from SU to DWG seems better, though, if you just want the geometry.
    PS: 3ds Max can import SketchUp files from version 6 through SketchUp 2014.
  1. Problem in dwg file import Revit then export gbXML file
    By roczhu in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2012, 11:47 AM
  2. What Revit Wants: Sketchup Import app for AutoCAD
    By luke.johnson in forum Blog Feeds
    Last Post: March 19th, 2012, 10:45 PM
    Last Post: March 15th, 2012, 12:15 AM
  4. Replies: 0
    Last Post: August 24th, 2011, 10:30 AM
