Thread: Editing the Properties of a Revision Schedule
    3,319
    08:30 PM
    I just beat my head against this for 20 minutes before I stumbled on the right trick, so I thought I'd post a Tip.
    More than likely, 2 years from now I'll have forgotten and will find my own answer when I do a search!
    When you want to edit the properties of the Revision Schedule on your Titleblock, here's what to do:
    • Edit the Titleblock Family
    • Expand the Views list Schedules category
    • Double-click on your Revision Schedule to open that View.
    So far, this is all normal. The problem is that once you are in the Schedule View, when you go the the Properties Palette, there's nothing there!
    The trick is called the Properties Filter.
    That's the drop-down menu towards the top of the Properties Palette
    At first, it probably says "Family:Title Blocks".
    Click on the Properties Filter drop-down menu and you will see Schedule: Revision Schedule (or whatever the name of your schedule is)
Name:	Revision Shedule Properties.PNG
    Select the Schedule, and NOW you can see the Schedule Properties you were expecting.
    See me in two years!
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    05:30 PM
    Whoever created this workflow, think it started in 2014, has irked me for quite sometime... Seems to happen with regular schedules time to time too... But yeah, mainly it's the revision schedule.
    Member BD Mackey's Avatar
    November 1, 2013
    480
    07:30 PM
    Same thing is true in families, most users don't realize they can change the cut plane of a family by using the same properties filter to change to the view and get View Range. That drop down is often overlooked.
    Las Vegas, NV
    4,864
    05:30 PM
    Quote Originally Posted by BD Mackey View Post
    Yeah, that one too.... Think it started when you could merge the Project Browser and the Properties Window...
    September 3, 2015
    ABQ, NM
    7
    06:30 PM
    Almost 2 years to the day.... Very helpful. Thanks for posting the solution!
    Junior Member urzoman's Avatar
    November 16, 2011
    5
    01:30 AM
    and still usefull thank you
    July 25, 2017
    11:30 AM
    Another way to get to the schedule properties is to select the schedule in the project browser.
  1. Editing in Schedule Views
    By iru69 in forum Architecture and General Revit Questions
    Last Post: December 10th, 2014, 01:39 PM
  2. revision clouds in legend views do not generate revision schedule entries
    By hclbaumbach in forum Architecture and General Revit Questions
    Last Post: July 1st, 2013, 10:39 PM
  3. Revision Schedule Parmeters
    By Charles Karl in forum Architecture and General Revit Questions
    Last Post: March 13th, 2013, 09:59 PM
  4. Editing a Panel Schedule MCB rating to MLO instead?
    By tzframpton in forum MEP - General
    Last Post: February 6th, 2013, 07:46 PM
  5. Tekeningenlijst/schedule van sheets met revision schedule
    By rijber in forum Nederlands forum
    Last Post: February 2nd, 2013, 01:50 PM
