Page 10 of 11 FirstFirst ... 67891011 LastLast
Results 91 to 100 of 109
Thread: Best fonts for annotation
  1. #91
    Member jsnyder's Avatar
    AUGI Refugee
    356
    01:00 AM
    Quote Originally Posted by Robert Roffe View Post
    My original drafting classes were based off ANSI guidelines, so I still don't use typically use I and O in documents (Alphanumeric lists are fine, gridlines not so much). And I have seen (and fallen prey to) confusion over I and O, not leading to coordination issues, but still needing more than a passing thought to understand what was on the page. A well-chosen font (and not photocopying photocopies) can mitigate this.
    Not a made up problem, but one that often seems to get blown out of proportion.
    I agree. The National CAD Standard also prohibits use of the letters I and O for grid designators. "To eliminate confusion with the numerals 0 (zero) and 1 (one), do not use letters O or I."
  2. #92
    11,098
    03:00 AM
    The "National BAD Standard" shouldnt even really be referenced as anything remotely close to a logical standard. I just had to write an email a few nights ago, about how its the least common denominator of crappy standards, written.
  3. #93
    July 10, 2015
    Boise, Idaho
    783
    02:00 AM
    I and O are a bit like paperspace in the bad old days. It still causes hair pulling screaming fits from enough people to make it not worth the hassle. There are other, more fun ways to cause people to lose their minds now. Roofs as roads for instance.
  4. #94
    3,178
    01:00 AM
    I still write zero and seven with the "slashes"... (see image) ... probably should put the tick at the top of the one
  5. #95
    September 19, 2017
    Seattle, WA
    93
    01:00 AM
    Precisely why I don't use that as justification. But when it comes down to it, there's nothing wrong about not using I and O. And there are much worse things you can do to a drawing to make it confusing and difficult to understand.
    Out of curiosity Aaron, if you had to pick an established standard to comply with, which would it be?
  6. #96
    11,098
    03:00 AM
    If i had to pick a standard to enforce and comply with, why wouldnt i use my own?
    What says the correct standard to *use* is one that was already written by a group-think bunch of people who are incentivized to see things done a certain way?
    My disdain for the NCS isnt because its a predefined standard that someone else wrote, its because its a ****** standard on the whole. Then there is that... horrid set of **** coming out of the UK, that im not even going to address, lol.
    FWIW, i wouldnt die on the hill of the I and O thing, either. I dont care if people use them, but its no skin off my back if they DONT use them, either. Certainly not an important issue, in my mind.
  7. #97
    6,387
    04:00 AM
    I still add a slash through my Z's
  8. #98
    Member tidalwave1's Avatar
    Las Vegas
    140
    01:00 AM
    I do not use the I and O as grid numbers. But, that hasn't stopped others I work with from doing so...
  9. #99
    3,178
    01:00 AM
    ...Certainly not an important issue, in my mind...
    Indeed, I imagine a contractor might wonder, "Is that grid 0 or O? for about a second?
  10. #100
    July 10, 2015
    Boise, Idaho
    783
    02:00 AM
    I know some that would send in an RFI and feign confusion until they could find a way to issue a change order
  1. Fonts in Revit
    Last Post: August 29th, 2014, 02:27 PM
  2. Standard fonts
    Last Post: May 7th, 2014, 04:21 AM
  3. What fonts do you use?
    By ThatBIMGuy in forum Architecture and General Revit Questions
    Last Post: April 12th, 2013, 03:23 PM
    Last Post: January 27th, 2012, 01:15 PM
  5. Revit OpEd: Fonts and fonts
    Last Post: July 7th, 2011, 10:10 PM
