Page 11 of 11 FirstFirst ... 7891011
Results 101 to 109 of 109
Thread: Best fonts for annotation
  1. #101
    December 8, 2010
    Long Beach, CA
    202
    01:13 AM
    Quote Originally Posted by DavidLarson View Post
    I know some that would send in an RFI and feign confusion until they could find a way to issue a change order
    Hahaha. So true.
  2.    #102
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    308
    04:13 AM
    Quote Originally Posted by cellophane View Post
    Have you looked at the Automating Automation stuff that Andreas Dieckman has been doing? There might be a way to streamline it even more
    edit - I also get two errors when I run it, although it seems to process everything even with the errors.
    I've just started preparing to switch over our text and have determined that some parameter results were coming up as null. This gets rid of the warning for people that care.
Name:	Text Style Script Errors.PNG
    Also don't forget to get rid of pull-downs in your script as much as possible. 2020 has added categories, types, etc. so try using by name if possible. You can use clockwork to get element types.Click image for larger version.
Name:	Text Style Script Errors 02.PNG
    Thanks, John Pierson for the pull-down tip and Greg for the original text style script.
  3.    #103
    July 26, 2019
    DFW, Texas
    51
    03:13 AM
    Well, I'm old enough to not use I, O, or Q, for grids--a legacy of when everything was drafted by hand (and that "Q" was complicated even with a Leroy set). Also, back in those days we all used diazio "resist" printing, so any blemish on the paper, or the printing paper would end up in the print. We uses sepia prints a lot, too, and the resolution of those could hadd "fuzz' to things that must needs be precise.
    This woudl be followed for lettered Keynots, as well.
    I'm alos old enough to have a habit of skipping over "13" just to avoid any issues by the supertitious. (Who might be clients, GCs, etc.)
  4.    #104
    July 26, 2019
    DFW, Texas
    51
    03:13 AM
    3 Not allowed! Not allowed!
    Back on topic, I'd love to be able to introduce Lexend. it's actually a scientifically designed font, brushed for best readability on screen and in print. It's slightly complicated in that t does not meekly follow typographic convention, but is organized more to need. Lexend Grand is a larger type scale that is not "bolder" nor more "expanded" than the non-grande.
    However, I'm far too well versed in "we've never dunnit before" stubbornness.
    For the curious, Lexend is open-source.
  5.    #105
    Forum Co-Founder Twiceroadsfool's Avatar
    10,594
    03:13 AM
    Quote Originally Posted by CapnMac View Post
    Good looking font! I might have to have my Dynabatcher convert a copy of the Template to it, to see if i like it.
  6.    #106
    November 23, 2012
    93
    01:13 AM
    That is funny.
    No question, all work on site would grind to a halt as a conseqence of the tremendous confusion created by the documents. Tremendous time delays, tell us what to do please.
  7.    #107
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    369
    10:13 PM
    Im quite fond of Gost Common
    easy to read & can fit more in a line than Arial
  8.    #108
    Senior Member willsud's Avatar
    December 13, 2010
    Ambleside, Lake District, UK
    974
    09:13 AM
    Then there is that... horrid set of **** coming out of the UK, that im not even going to address, lol.
    That made me laugh, thanks.
    This could apply to so many things currently but in general I despair of our country's tendency to over-elaborate - or maybe it is just the BSI - or maybe it is just me not being clever enough
  9.    #109
    July 7, 2017
    Hernando, MS
    528
    03:13 AM
    We use Calibri over here for almost everything. A few things like view titles and other titleblock info are Century Gothic. For most text we do Calibri 3/32". For dimensions we do 3/32" Calibri set to 0.8 width, and spaces suppressed. We even have our SpecLink spec software set to Calibri for specifications.
    We transitioned to Calibri back about 5-6 years ago, coming from that nasty old ArchiText font. I liked that font when I was younger, but now after using Calibri, ArchiText just looks YUCKY!
  1. Fonts in Revit
    Last Post: August 29th, 2014, 03:27 PM
  2. Standard fonts
    By Cyus in forum Architecture and General Revit Questions
    Last Post: May 7th, 2014, 05:21 AM
  3. What fonts do you use?
    By ThatBIMGuy in forum Architecture and General Revit Questions
    Last Post: April 12th, 2013, 04:23 PM
