Thread: Trouble Converting Ceiling Based Family into Face Based
    January 5, 2015
    12
    03:45 PM
    Hi all,
    I have 3 Ceiling Based families that I am looking to convert to face based so they can be hosted on a generic model family.
    I have hunted around for a solution and the best method to get this done seems to be hosting the families in a temporary file, then linking this into another temp file and copy/monitoring the families into that project (As this apparently updates them to face based).
    Problem is, I am unable to select the linked families once I enter the copy/monitor dialogue.
    I am working in Revit Architecture 2014, and the it seems that only MEP fixtures can be copy/monitored. I have updated the family category for the fixtures to Mechanical Equipment (As this is what they are), but still find myself unable to select them once they are linked.
    Anyone know why I would running into this?
    Cheers
    Edit: After a bit more searching, it seems that the families must come directly from an MEP model, and that converting their category in Revit Arc isn't enough... Is that the case?
    Member BD Mackey's Avatar
    November 1, 2013
    477
    08:45 AM
    You are correct must have Revit or Revit MEP for that to work
    January 5, 2015
    12
    03:45 PM
    Hmm, looks like we'll have to re-model then...
    Thanks!
  1. Convert Wall Based to Face Based
    By zsmith3 in forum Architecture - Family Creation
    Last Post: August 6th, 2014, 03:29 PM
  2. Convert a Family from Wall Based to Face Based.......
    By doni49 in forum Tutorials, Tips & Tricks
    Last Post: May 23rd, 2013, 09:02 AM
  3. Face Based placement without ceiling views?
    By GabrielBlack in forum MEP - Family Creation
    Last Post: January 14th, 2013, 09:53 PM
  4. Face Based VS Wall Based VS Non-Host with Void Families
    Last Post: December 16th, 2011, 04:20 PM
  5. Face based Ceiling Fan
    By JCM in forum Architecture - Family Creation
    Last Post: April 7th, 2011, 11:43 PM
