Thread: Wall offset deforms the floor
    April 9, 2015
    5
    05:00 PM
    Dear friends,
    I have an issue which I couldn't find a answer on Google so far.
    When I try to offset those walls on attached file, they deforms (moves the lines) of the floor either. There is no control over properties panel and the only way I could solve this issue is to cut and paste the wall.
    But what I think is that there should be a property(!)
    Please check out the attached file.
    Regards,
    - Mehmet Ali
    February 2, 2011
    Montreal/Paris
    828
    09:00 AM
    When you created the floor Revit "attached" it to the wall(you probably used Pick Walls). The easy way to break this relationship is to cut & paste.
    2,820
    12:00 AM
    This often happens even when you don't use 'pick walls' and it frustrates the **** out of me! It's one of those automagical feel good Revit features. I agree with the OP, this (and other features) should have on/off switches.
    April 9, 2015
    5
    05:00 PM
    Thanks for the answers folks.
    So we may call it as bug, right?
    2,820
    12:00 AM
    Well...like consistently joined walls it would be called a 'feature'.
    welcome to the forum btw.
    April 9, 2015
    5
    05:00 PM
    Thank you guys!
  1. Wall Top offset gets lock with top slab
    By anubhav1237 in forum Architecture and General Revit Questions
    Last Post: March 25th, 2015, 11:17 AM
  2. Curtain Wall Offset Mullions Both Continuous
    By veuxx in forum Architecture and General Revit Questions
    Last Post: August 7th, 2014, 05:00 PM
  3. Curtain wall offset
    Last Post: July 21st, 2014, 07:10 AM
  4. Curtain Wall with base offset of 2' - help please.
    By digitalputty in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2012, 08:42 PM
  5. Offset Curtain Wall Panel
    By DaveP in forum Tutorials, Tips & Tricks
    Last Post: June 8th, 2012, 08:15 PM
