Results 1 to 9 of 9
Thread: Create New App Macro, help
    December 9, 2010
    74
    06:08 AM
    I am trying to create a new Macro (Revit 2011) by following a sample from AU and I am receiving an error message on the folowing lines:
    Dim baseVec As Autodesk.Revit.Geometry.XYZ = Me.Create.NewXYZ(1.0, 0.0, 0.0)
    Dim upVec As Autodesk.Revit.Geometry.XYZ = Me.Create.NewXYZ(0.0, 0.0, 1.0)
    Dim origin As Autodesk.Revit.Geometry.XYZ = Me.Create.NewXYZ(0.0, 0.0, 0.0)
    The message reads: Type" Autodesk.Revit.Geometry.XYZ" not defined.
    I searched the web for answers but cannot find the key, where do I go from here?
    Patrick
    Member krispy5's Avatar
    December 22, 2010
    68
    10:08 PM
    There was a major overhaul of the API between 2010 and 2011... looks like the sample code you are using is for 2010.
    the Autodesk.Revit.Geometry namespace does not exist in 2011, use Autodesk.Revit.DB.XYZ instead
    Moderator mark b's Avatar
    NSW Australia
    1,434
    10:08 PM
    Quote Originally Posted by krispy5 View Post
    Bit off topic but.
    Welcome Kristian glad you made it over.
    Are you the same "kind person" Kristain who sent me that wonderful little Text align app ?
    A fantastic little tool, thanks again
    Maybe you would like to share this and anything else you have to offer in the API section,if you are him ?
    December 22, 2010
    68
    10:08 PM
    Yes Mark, that's me
    New Member hjaff1's Avatar
    September 14, 2017
    12:08 PM
    Hi I wounder if anyone can help me!
    2 things!
    I wonder if you can help. I have a schedule of all of my elements in the model, and I want to put my name to all of those element that I have modeled in Revit. how can I do that in Revit with a macro?
    I normally export the schedule to Excel and fill everything and re-Import it back to the schedule.
    the next one, is a little different, I have to put "0001 to however many element that I have in that shcedule" sometimes I have 50+ element, again, I normally export the schedule and fill in the numbering and re-import back to Revit!
    so,
    1-under the title "Designer" I need to put "My Name"
    2- Under the title "Item Number" put a sequence number starting from "0001" to as many elements that I have in the schedule.!
    is this possible at all?
    I tried everything that i can but i didnt have any luck, but I dont have the programming brain!
    Please help if you can!
    sorry to take up your time and thanks in advance!
    10,790
    05:08 AM
    Can you clarify "everything" that you tried? IE: What specifically have you tried, already, that hasnt worked?
    September 14, 2017
    12:08 PM
    Hi Twiceroadsfool
    thank you for the reply.
    I tried to write a macro code I couldn't get it to work, and tried recording a macro on excel and tweak it to work in revit, that dint work too!
    I just dont know how to write it..!
    September 14, 2017
    12:08 PM
    this is what My Schedule heading looks like this:
    Family_Name l Family_Type l Object_Size l Building_Code l Location l Created_By l Item_Number
    so,
    1-under the title "Created_By" I need to put "My Name" for all of the objects, 50+ sometimes more...
    2- Under the title "Item_Number" I need to put a sequence number starting from "0001" and finishing with however many elements that I have in the schedule, 50+ sometimes more...
    February 16, 2013
    6
    07:08 AM
    Hi - There are some code examples showing how to set parameter values on my blog at https://boostyourbim.wordpress.com/category/parameters/. My online video course on the Revit API at http://bit.ly/revitapi would be a great way to quickly learn the fundamentals and more.
    Regards
    Harry
  1. Create a family warning
    By Drew in forum Architecture - Family Creation
    Last Post: May 31st, 2011, 05:34 PM
  2. WORK FOCUS cool app
    By gaby424 in forum Out There
    Last Post: May 12th, 2011, 02:56 PM
  3. How to create 2d truss?
    By pjetrus in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2011, 04:58 AM
  4. Export Families App
    By mark b in forum Third party Add-Ins, API and R&D
    Last Post: February 28th, 2011, 02:06 AM
