Thread: Arch wall is showing up on top of my metal stud framing.......
    Member ecraider's Avatar
    May 19, 2014
    Concord, CA
    87
    08:12 AM
    I am showing metal stud framing inside of this wall and the wall is always showing up on top of my studs/headers etc.
    I want the framing to be on top of the wall........ is there a way to change this?? there is no send to back command on these object because they are 3d.
    Is there a hierarchy option that I can check off to show struct columns and framing above walls??
    See attached screenshot!!!
Name:	150526_STUDS UNDERNEATH WALLS......JPG
    2,822
    01:12 AM
    No but I'm pretty sure it will print okay.
    May 19, 2014
    Concord, CA
    87
    08:12 AM
    Just tried to plot it... it plots exactly how is look onscreen with grayed out wall on top of metal stud framing.... I guess i will need to get into the wall layers and set different materals to them but this is way more work than I wanted to get into here.
    December 20, 2010
    1,126
    04:12 AM
    Can you create a filter to set the arch walls to transparent?
    July 3, 2015
    04:12 PM
    You need to select the column and then unjoin it from the wall. (Modify|Columns tab >Geometry>pull down Join to Unjoin).
    Classic trick, but does the job. This always happens when an element is placed fully into another element it automatically joins.
  1. Pre-Engineered Metal Building Framing
    By WVReviter in forum Architecture - Family Creation
    Last Post: December 26th, 2016, 11:58 AM
  2. Metal Stud Wall Family from video
    By billiam in forum Architecture and General Revit Questions
    Last Post: November 4th, 2014, 11:07 PM
  3. stud wall framing - which templates to use?
    By troypiggo in forum Architecture - Family Creation
    Last Post: June 8th, 2014, 10:50 AM
  4. Glass blocks in metal stud wall
    By boriskam1991 in forum Architecture and General Revit Questions
    Last Post: February 24th, 2013, 10:37 AM
  5. metal wall framing
    Last Post: June 19th, 2012, 01:10 PM
