Results 1 to 10 of 14
Thread: Add blank line after heading in drawing index - how?
    Junior Member mmklin's Avatar
    June 8, 2015
    Gteborg, Sweden
    5
    11:45 AM
    Hi there
    I'm making a sheet of a drawing index. It's pretty easy to format the schedule and add a blank line after each category or to space out every item on the list, but how do I get a little more space after the category/heading, ie between "45.1 HUSKOMP..." and "A-45.1-0001"?
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,579
    02:45 AM
    Quote Originally Posted by mmklin View Post
    Hi there
    have you tried "Blank row before data" on the Appearance tab in the schedule View List Properties dialog?
    June 8, 2015
    Gteborg, Sweden
    5
    11:45 AM
    I would, but it's greyed out, seemingly no matter what other options I've made.
    Moderator mark b's Avatar
    NSW Australia
    1,436
    07:45 PM
    Check either "show title" or "Show Headers" to make "Blank row before data" active
    NSW Australia
    1,436
    07:45 PM
    There is another way-
    1. select the row or cell (title)
    2. menu bar select "resize"
    3. increase the value this will give you a bigger offset (boundary)
ID:	22263   Click image for larger version.
    June 8, 2015
    Gteborg, Sweden
    5
    11:45 AM
    Aha, but I want a space after each CQ Header and not just at the top, which I get if I do it the "Blank row before data"-way.
    (In either case I don't want to tick to show the real view name/schedule name, because I've got three separate schedules which should all be labelled "Ritningar" (Drawings) on their respective sheets, but seeing as they're not allowed to have the same name in the properties tree I've had to add extension to their names that I don't want to show up on the sheet. So I've got the overall title for the sheet placed as text instead).
    The resize height-button is greyed out. And the adjacent option of "Insert [row] above selected" is greyed out too, otherwise that would've been super handy!
    NSW Australia
    1,436
    07:45 PM
    I think I understand.
    If you use "Schedule Header" (title) you can select the cell (title) then hit "clear cell" on menu bar and type in what you like, this can be different from the schedule name. Then you can have all the options of resize etc..
ID:	22271   Click image for larger version.
    June 8, 2015
    Gteborg, Sweden
    5
    11:45 AM
    Great, thanks! There's usually an embarrassingly simple solution, the trick is just to find it
    Now only my original problem of not finding a way to get a blank space between each category/heading and the items remain. Thoughts on that?
    3,202
    02:45 AM
    Revit isn't going to let you put a space there. If you meet a contractor that tells you, "Sorry, we can can't build your project because there is no space between your schedule header and the data"...I'd like to meet them.
    If you really really must have it your way, then have a look at IDEATE's Sticky application. It will allow you to export your data and then import it, reassembling it to match the structure and format you want. It takes advantage of the customization that we can do in the header portion of schedules. It extracts the data and then reassembles it all in the header by creating rows and columns it needs there and then plugging in the data using the revised format defined outside Revit.
    June 8, 2015
    Gteborg, Sweden
    5
    11:45 AM
    Steve_Stafford - The question wasn't what contractors want, it was if I had been missing an easy way to do a simple thing like adding a blank row in a technically advanced programme like Revit. The answer to that question was no. Thanks for your input, though
    I guess there's no easy way to get just one row of data in a schedule to be grey in colour instead of black then either? Because Revit seems to only want to allow various formatting of columns, not rows.
  1. Drawing Index & Issued Revisions
    By Chadwick17 in forum Architecture and General Revit Questions
    Last Post: September 8th, 2017, 07:09 PM
  2. Drawing Index
    By kowen1208 in forum Architecture and General Revit Questions
    Last Post: April 7th, 2014, 04:03 PM
  3. Blank line in a revision schedule?
    Last Post: December 20th, 2013, 12:37 AM
  4. In my section drawing my columns are just represented as a single line.
    By andrew333 in forum Structure - General Questions
    Last Post: November 21st, 2012, 03:00 PM
  5. Drawing Index with sheet number scheduled twice
    By lboylan in forum Architecture and General Revit Questions
    Last Post: October 15th, 2011, 12:13 PM
