Thread: HELP: FloorType in Room with C#
    June 12, 2015
    Lima, Per
    11:47 AM
    Hello everyone:
    How I can to assign floor type (FloorType) in Room?.
    I'm using "ActiveUIDocument.Selection.PickObjects"
    See image:
    I'm trying the folowing code:
    Code:
    //Selected Rooms
    IList<Reference> eRefList = m_revit.ActiveUIDocument.Selection.PickObjects(Autodesk.Revit.UI.Selection.ObjectType.Element, new RoomSelectionFilter(), "Please pick some element to delete. ESC for Cancel.");
    foreach (Reference eRef in eRefList)
         if (eRef != null && eRef.ElementId != ElementId.InvalidElementId)
    //Get Id FloorType
    Autodesk.Revit.DB.FloorType mytemp = (from v in new FilteredElementCollector(m_revit.ActiveUIDocument.Document).OfClass(typeof(Autodesk.Revit.DB.FloorType)).Cast<Autodesk.Revit.DB.FloorType>()
    where v.Name == typeFloor
    select v).First();
    TaskDialog.Show("Rooms", eRef.ElementId.ToString() + "TypeFloor :" + mytemp.Name + "Id: " + mytemp);
    //This code for to assign FloorType in Room
    Thanks for your help.
    Regards,
    David
    June 12, 2015
    Lima, Per
    11:47 AM
    Hello everyone:
    See image:
    Code:
    Code:
    //Selected Rooms
                                //Get Id FloorType
        select v).First();
    Regards,
    David
  1. Room bounding walls & and room separators. Rooms have no boundaries?
    Last Post: September 26th, 2013, 08:53 PM
  2. Find Room Element by Room Number?
    Last Post: September 17th, 2013, 06:22 PM
  3. NEW PROJECT File>Create room>Room number is three. Want it to start at 1.
    Last Post: June 29th, 2013, 04:57 AM
  4. Specialty Equipment in Room but not Room Aware
    Last Post: January 26th, 2012, 08:36 AM
  5. Adding Room / Room Tag too Linked models
    By Raigoki in forum Architecture and General Revit Questions
    Last Post: January 9th, 2012, 02:56 PM
