Thread: Shared Parameters - Blank Fields - Hide Question Marks
    July 22, 2014
    39
    03:11 PM
    I am building an Electrical Tag to show Mounting Height and some descriptive info for my outlet families like this:
    +42"
    GFCI
    WP
    if I omit a field, or multiple fields I get a tag that looks and prints like this
    +42"
    is there any way to hide the question marks if the text field is blank?
    June 10, 2012
    27
    03:11 PM
    Try to put the parameters in the same label. They will then only show up in the tag if the param is filled with info.
    Skickat frn min iPhone med Tapatalk
    September 26, 2012
    USA
    132
    11:11 AM
    Or, you could create some on/off visibility parameters for the other labels so the user has the option to hide them when not used.
  1. Revit OpEd: Shared Parameters are Shared Definitions
    Last Post: February 27th, 2015, 03:15 PM
  2. Labels - Can they be left blank without Question Mark appearining
    By domsib in forum Architecture - Family Creation
    Last Post: November 28th, 2013, 09:25 AM
  3. Parameter Question Marks
    By RaiderArch in forum Architecture and General Revit Questions
    Last Post: March 18th, 2013, 08:12 PM
  4. Import shared parameters into an existing shared parameters file
    By Ree in forum Architecture and General Revit Questions
    Last Post: January 14th, 2013, 09:34 PM
  5. What are those question marks below categories??
    By ahmed_hassan in forum MEP - General
    Last Post: March 14th, 2012, 01:00 PM
