Thread: Shape Handles & Split Faces
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    220
    04:58 PM
    Hi All,
    I currently like to use split faces to control the locations of connectors on my bigger sized families (like a RTU). However, it appears that this brings in shape handles and I'm wondering if anyone knows how to not have shape handles.
    Thanks
    3,247
    06:58 PM
    What is the relation between split faces and connectors? That's not clear. Can you provide an example?
    December 29, 2014
    Calgary, Canada
    220
    04:58 PM
    The split faces are used to host the connectors.
    So an example would be a roof top unit where the two ducts come off the bottom of the unit, or the gas line connects flush with the face of the geometry. I would use a split face as a host to control where the connector is located on the face of the geometry.
    3,247
    06:58 PM
    You mean, you split a surface in a family to find a specific place for a connector instead of the default center of the face? I am trying to understand. If a connector needs to be off center, the location can be controlled by parameters. I still don't see why you would split the face of the duct to place a connector. Wouldn't that affect the graphics of the duct in the project, showing extra lines on the surface?
    December 29, 2014
    Calgary, Canada
    220
    04:58 PM
    Yes. you are saying that I can control the location of the connector directly? I was under the impression that the connector could only be at the center of the face.
    The extra lines wouldn't be a problem as there are actual holes there, they just happen to be flush with the overall face.
    3,247
    06:58 PM
    Quote Originally Posted by evan.dodds View Post
    The center location is when you use the placement by face. If you place by workplane, you can drive the location of the connector by parameters.
    December 29, 2014
    Calgary, Canada
    220
    04:58 PM
    Ooh, neat-o! Thanks!
  1. Unwanted Shape Handles
    By DaveP in forum Architecture - Family Creation
    Last Post: December 9th, 2014, 03:38 AM
  2. Hiding Split Faces
    Last Post: September 18th, 2014, 08:15 AM
  3. Beam shape handles
    By Henry in forum Structure - General Questions
    Last Post: February 24th, 2014, 07:34 PM
  4. Flexing Tag Family - Shape Handles
    Last Post: September 8th, 2011, 10:23 PM
  5. Shape handles
    By Randy_CaS in forum Architecture - Family Creation
    Last Post: September 2nd, 2011, 01:43 PM
