Thread: Inclined (sloped) beams and slab.
    December 12, 2010
    New York
    322
    05:42 AM
    Can you please tell me if this is possible in Revit?
    Our architect wants for a building, that the slab over the last floor to have a slope. More precisely, the front columns are 1.5m higher then the ones from the back. So, we need to make the beams and the last level slab inclined.
    Attached to this problem comes another one:
    Between the front column (which is 1.5m higher then the one from the back), we have other 3-4 columns. How can I extend them up to the beam? (i dont want to compute the hight with Acad).
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,543
    06:42 PM
    Quote Originally Posted by lucis29 View Post
    I'm a window/curtain wall detailer so I don't deal with floors, beams, or columns much but just playing around it's easy to create a sloped floor using a Slope Arrow when placing the floor. You can specify the height of the floor at the head and tail of the the Slope Arrow to have whatever slope you like. Then select the columns and use Attach Top/Base and the top of the column will follow the floor slope where ever they occur. Hopefully it's as simple as that. If not, someone else in the know will be here soon to straighten us out
    December 12, 2010
    New York
    322
    05:42 AM
    Thanks Dave.
    I fixed the inclined slab and the attachment of the columns. Now I only have the problem with the beams.
    How can i make a beam follow the inclined path of the slab?
    3,215
    09:42 PM
    Thanks Dave.
    There are several solutions.
    One solution is this: after you have fixed the height of the columns using Attach > Top, as per Dave's reply, go to a floor plan, and draw a beam, activate "3D Snapping" and set a Z-direction justification > top or bottom in the properties window. Click on the center of the first column, and then on the center of the last column (see image 1). Then, go to a section and see if the beam is correct. If it is, go back to a floor plan, and copy that beam from one grid line to the others.
    Another solution is this: using the beam system tool, create a set of beams based on the reference plane created by the lower face of the slab or roof. This has the advantage that if the slope of the slab or roof changes, the set of beams will follow the slope. (see image 2), (saved from my old Augi posts).
    Dave Jones's Avatar
    4,543
    06:42 PM
    Thanks Dave.
    I would make a new reference plane at the bottom of the slab, name it, then select the beam and use Pick New to select the sloped reference plane. You should be able to lock the beam to the ref plane. Once again, I'm no expert at this type of construction so this is all "by guess and by golly"
    yeah, what Alf said
    December 12, 2010
    New York
    322
    05:42 AM
    Thank you Alf. The problem was with the 3D snap not being checked.
    Now there is a problem with the beam that attaches to the bottom of the slab. How can I attach it to the top of the slab?
    Should I offset the slab with its thickness?
    02:42 AM
    I would use the Reference Planes-method. Draw a refplane under the desired angle and place the beams on this reference plane. You can choose to place the plane on the bottom or top of the slab, just move it around and beams will follow.
  1. Playing Around with Tapered Beams
    Last Post: April 7th, 2014, 11:32 AM
  2. Lintels / Concrete Beams above Openings need more information...
    By crhdesign in forum Architecture - Family Creation
    Last Post: May 16th, 2011, 08:51 AM
  3. OOTB Content for Beams/Columns
    By TheViking in forum Structure - General Questions
    Last Post: May 7th, 2011, 05:57 AM
  4. Beams and Stacked Walls
    Last Post: April 19th, 2011, 08:11 PM
