Thread: Exterior camera views shows lights in building but interieur camera view does not ??
    March 19, 2014
    49
    05:34 PM
ID:	22507Click image for larger version.
    In the above images you can see an interior view and exterior view. In the exterior view the lighting fixtures are being rendered but in the interior view not. I don't understand why. Both views have exactly the same view templates.
    Why does the interior rendering fail to render them?
    Can anyone help me?
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    338
    04:34 PM
    it seems strange, when you say you are using to similar View Templates. Still, i just found out that these two settings are to be found in the "rendering settings" part of your VT:
    So you need to apply them to your rendering, if you didn't do that already.
    if it's still giving you trouble, try uploading your project, we'll take a look.
    March 19, 2014
    49
    05:34 PM
    Well the lighting scheme is exterior and artificial lighting with artificial light active. This is contained in a template view and when rendering one camera view with this template it renders fine.
    But when i made a new camera view and assigned the same template view the rendered file showed no artificial lighting!
    It works now but the failed view i changed the view template to none, then selected another one and reselected the correct one and now it renders the same!
    So probably the view template settings in revit are a bit unstable?
  1. Alive in the Lab: Artoo In Live: Lights! Camera! Fabrication!
    By Alive in the Lab in forum Blog Feeds
    Last Post: April 6th, 2015, 11:15 AM
  2. Resizing Camera Views
    By emuldoon in forum Architecture and General Revit Questions
    Last Post: November 5th, 2014, 04:34 PM
  3. Security Camera Views
    By rkitect in forum Out There
    Last Post: March 2nd, 2012, 08:53 PM
    Last Post: January 25th, 2012, 06:15 AM
  5. Re-sizing 3d Camera Views
    Last Post: June 8th, 2011, 11:52 AM
