Thread: Shared Parameter Error
    May 21, 2015
    12:38 PM
    Hi all,
    I am getting this message when I try to insert a manufacturers window into my project. I have inserted other families that the manufacturer provides, with no issues. I tried to find the shared parameter that might be causing the problem; thinking that I could just do some name changing and fix the issue, but I can't locate it....Any ideas?
Name:	Shared parameter error message.JPG
    6,389
    03:38 PM
    You are getting a GUID conflict. Unless I'm completely off-base, you will need to change the GUID for one of the two parameters - I would change the manufacturers. There are some GUID generators online: https://www.guidgenerator.com/online...generator.aspx
    http://www.revitforum.org/architectu...d-numbers.html
    May 21, 2015
    12:38 PM
    Thx a bunch!! I'll look into that. WOW! What a fast response
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,570
    12:38 PM
    Quote Originally Posted by keusted View Post
    Heh, that's nothing. The World Record response time in RFO is 13 seconds. Also set by none other than Chad, aka Cellophane, aka "The Librarian". This is an Awesome place!
    6,389
    03:38 PM
    Heh, that's nothing. The World Record response time in RFO is 13 seconds. Also set by none other than Chad, aka Cellophane, aka "The Librarian". Chad is the Awesome
    Fixed that for you
    To add to my earlier response - I would change the manufacturers parameter because changing yours could lead to issues downstream (assuming one of the parameters in the screenshot is yours, not the mfr.)
  1. Shared Parameter - Can i create a new Typen of Parameter?
    By umotta in forum Architecture and General Revit Questions
    Last Post: January 13th, 2015, 01:02 PM
  2. Could i change family parameter to shared parameter?
    By dedo in forum Structure - General Questions
    Last Post: August 19th, 2014, 01:11 PM
  3. shared family and <family type.....> parameter, when loaded error
    By Bross in forum Structure - Family Creation
    Last Post: November 25th, 2013, 11:56 AM
    Last Post: August 11th, 2011, 07:20 PM
  5. Convert Project Parameter to Shared Parameter
    Last Post: January 5th, 2011, 07:35 AM
