Thread: Need tutoring from an expert
    August 7, 2015
    USA
    11
    09:56 AM
    Question Need Quick Tip from an expert
    The file has 2 Wye, i created the top darker one. when the bottom Wye branching pipe is stretch the Radial point is the Insertion of the family.
    How can i mimic that on mine. My Radial point is not the insertion point, its the pipe connector. thus I can't turn my Wye into a Tee.
    Thanks.
    Last edited by RubberDinero; August 10th, 2015 at 04:46 PM. Reason: Shorter issue description
    3,231
    12:56 PM
    Please contact me. My email address is in my signature.
    August 7, 2015
    USA
    11
    09:56 AM
    Still accepting help with this issue. Thanks
    August 7, 2015
    USA
    11
    09:56 AM
    In a WebEx meeting with our BIM Lead, he explained how to make it radial in less then 5 seconds. I was so easy, it made me look so entry level. Which I am to Revit, but still. Thanks everyone for your interest.
    3,231
    12:56 PM
    Quote Originally Posted by RubberDinero View Post
    Glad to know that you found help. I'd like to say a couple of things about this thread:
    Since you started a thread for this question, it is a good etiquette of the forum to "close" a thread by sharing the solution, not only saying that a solution was found but without sharing the solution. Someone else might come to this thread later on, looking for a solution to the same issue.
    Also, I'd like to add a brief note explaining my post # 2 above. The original question of the thread was a more elaborated question, and it included a request for "tutoring", and I understood that as a request for private training on creating pipe fittings with look-up tables. After the original question was edited, my reply looked strange, and that's why I want to add this comment to clarify my post.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    08:56 AM
    Your BIM Lead should be your first POC for Revit issues before outside contact....As he/she may have a specific direction for project content vs outside help.
    August 7, 2015
    USA
    11
    09:56 AM
    Except I was trying to mimic a part, for my own understanding, that was already created. Not a whole lot of different directions you can have for a Tee/Wye.
  1. teaching/tutoring Revit
    By afwelch87 in forum Tutorials, Tips & Tricks
    Last Post: March 22nd, 2020, 02:08 AM
    Last Post: April 29th, 2015, 07:45 PM
    Last Post: April 15th, 2015, 07:45 PM
    Last Post: April 15th, 2013, 05:45 AM
    Last Post: August 16th, 2012, 03:15 AM
