Results 1 to 10 of 11
Thread: Wall opening enlarged during copy/monitor
    Member trevorpan's Avatar
    February 3, 2014
    Tempe, AZ
    198
    04:46 PM
    Had an issue where tilt wall openings are enlarged during the copy monitor process. Each panel will need to be adjusted.
    Has anyone run in to this? Is there a way for the openings to come in at the right size?
Name:	WALL OPENING.png
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    296
    06:46 PM
    I think this may have something to do with the door family that is being monitored. Depending on how the reference planes are identified (strong, weak, not a reference), the extents of the opening on the tilt wall may vary.
    Wellington, New Zealand
    729
    11:46 AM
    Its all abit dodgy. Instead of the copied opening being based on the opening void (or rough height/width) within a opening family, its actually based on the extent of the opening families elements: so (in the case of doors) it will go to the edge of the trims/architraves or sill, what ever is the largest part, not the rough opening (as per image below). By memory it will also go to the extent of any symbolic elements: so if you have a door swing at 180 degrees opening, the copied opening will be almost twice as large as it should be
    3,171
    04:46 PM
    It is as Alex describes it unfortunately.
    Using the stock content, the only option is to not create openings when using Copy/Monitor for walls. There is also another reason not use it for walls, the walls are aligned (watched) based on Location Line and if you swap a wall type and move it, that will trigger a coordination review warning. It is necessary to place walls separately and then use the Monitor function only to allow you to place a different wall type in the correct location relative to the linked wall. The scenario I'm describing is placing a structural only wall in the correct location over a compound wall that is in the linked file.
    Fwiw, door families that use nested panels and frames do not suffer from this issue, creating larger openings. All the stock families do however. The families that you'll find shared here by Twiceroadsfool will work with copy/monitor, at least far better than the stock doors.
    729
    11:46 AM
    hmmm - some more investigation is required. All our RevitWorks Door Factory doors are made completely with nested components, and the copy/monitor bug still exists - I wonder why?
    (Ive just tested with shared and non-shared nested families)
    3,171
    04:46 PM
    Do you have geometry in the patent family? If so that's why. Wrote about this one the past.
    729
    11:46 AM
    No geometry in the parent family - other than the opening
    February 3, 2014
    Tempe, AZ
    198
    04:46 PM
    Hi all,
    thank you for the insight. I'll forward this post to the architect and perhaps they can look into their families.
    Great post too Steve ~
    3,171
    04:46 PM
    Quote Originally Posted by Alex Page
    Hmm, seems something has changed since I wrote that post (before 2015 R2). 2015 R2 and 2016 are both responding differently now. I also noticed something I don't recall being documented. They've given us an option for which Location Line the C/M wall should reference. Going to have to do some experimentation now.
    July 7, 2017
    12:46 AM
    Hello,
    I know this is too late for you but this was happening to me and I was able to fix it.
    In my case I had a window family with nested families for the geometry. It turns out that one of the nested families was invisible in all views and was causing the problem.
    So I went to the project browser and deleted this family (it was not necessary).
    I hope this can help to someone because it was really frustrating.
    Regards
  1. Copy/Monitor / Wall Collaboration Difficulties
    By Peter1979 in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2014, 07:48 AM
  2. Do U Revit: Copy/Monitor & Batch Copy for MEP Update
    Last Post: November 22nd, 2013, 02:45 AM
  3. Do U Revit: Copy/Monitor & Batch Copy for MEP
    Last Post: November 21st, 2013, 02:15 AM
  4. Copy Monitor
    By leetecture in forum Architecture and General Revit Questions
    Last Post: October 2nd, 2012, 10:47 PM
  5. copy - monitor
    By jbenoit44 in forum Structure - General Questions
    Last Post: December 20th, 2010, 05:48 AM
