Thread: Light fittings
    January 11, 2011
    UK
    53
    05:13 PM
    Light fittings
    Im just doing an electrical plan and was wondering how people deal with showing pendant light fittings on floor plans?
    at the moment im using plan regions, is this the best method?
    Senior Member willsud's Avatar
    Ambleside, Lake District, UK
    981
    04:13 PM
    I seem to recall seeing a tip whereby if you included a 3D line within the family, drawn down from the fitting which was cut by the View cut plane then the whole fitting would show up in plan... or maybe I was imagining that - I've not tried it but it always sounded a good idea.
    Have you had a look at the Andekan free lighting family samples - they are quite 'illuminating'
    http://www.andekan.com/revit-family-free-sample
    Member rosskirby's Avatar
    Marietta, GA
    139
    11:13 AM
    Will is right, just make sure you use an "invisible" model line drawn all the way down to the reference level. That way there will technically be a modeled portion of the fixture cut by the cut plane, and since light fixtures are a non-cuttable family, the entire object will show up in your plan view.
    04:13 PM
    Also check out Visa Lighting. Awesome families, all work great.
  1. exterior light for rendering
    By Pickens in forum Architecture and General Revit Questions
    Last Post: July 11th, 2011, 05:37 AM
  2. Where can I find families for plumbing fittings?
    By maxesicu in forum MEP - Family Creation
    Last Post: July 1st, 2011, 11:15 PM
  3. Light Fixtures Using IES Files
    By ELaforge in forum MEP - Family Creation
    Last Post: May 4th, 2011, 09:21 PM
  4. Natural light intensity
    By lovi in forum MEP - General
    Last Post: March 19th, 2011, 12:55 AM
  5. Light Fixture Tags
    Last Post: February 18th, 2011, 07:53 PM
