Results 1 to 10 of 14
Thread: RST Q1: Formwork drawing
    Moderator gaby424's Avatar
    December 11, 2010
    912
    11:39 PM
    A revit structure guy asked me if it is possible with RST.
    It is possible to have the cropped sections of structural beams and floors displayed over the structural plan?
    (see picture)
    p.s. these is the graphic standard here for a concrete formwork drawing.
    If not, how can you do it with RST?
    Nantes, France
    1,381
    11:39 PM
    this has to be detail components, or a crazy workflow by putting cut views upon the sheet. no other way.
    December 11, 2010
    912
    11:39 PM
    ok. The cut view was an idea for me first time but it`s indeed an crazy workflow. So then, the question is, in US where RST is developed, what is the drawing convension to provide the formwork floorplans for the workers that can be extracted from RST? Or there are not such kind of floorplans as a concept? I mean, i want to see if RST have something like that, maybe we can adapt with the out of the box RST convention and explain it to the constructor.
    Member Hirvio's Avatar
    March 8, 2011
    Zagreb, Croatia
    260
    10:39 PM
    I'm so glad someone asked that. In my very first Revit CD, I did just what Julien said was the only reasonable thing.
    Lots of section views, view template with filter, extra dimension style for rotated views...
    But I wouldn't like to do it again, especially if some multi-storey building comes up.
    I was expecting that RST has some better tools for formwork plans, and I'm very disappointed if it is not a case. Worst of all, here in Croatia, it is usually an Architect's job, not Structural Engineers...
    09:39 PM
    Thank the lord we can do this on separate drawings... only section markers in the structural floor plans.
    Nantes, France
    1,381
    11:39 PM
    if having plan and cut views at the same place is your standard, I would suggest you to use callouts referencing cut views, so you can put the cut view on the sheet very close to the callout. hopefuly I don't have to do this, I use plan views and cut views separately.
    Autodesk TheViking's Avatar
    Lexington, MA
    157
    05:39 PM
    Quote Originally Posted by gaby424 View Post
    Where is here?
    December 11, 2010
    912
    11:39 PM
    romania almost near croatia
    Lexington, MA
    157
    05:39 PM
    How would you add rebar to such a dense drawing?
    March 8, 2011
    Zagreb, Croatia
    260
    10:39 PM
    Rebar goes on a separate layout, where formwork is shown as outline only.
  1. Cannot see pipes on drawing?
    By lovi in forum MEP - General
    Last Post: August 8th, 2011, 02:48 PM
  2. Any stair drawing example?
    Last Post: June 27th, 2011, 02:59 PM
  3. RST Structural Usage
    By gdoherty0102 in forum Structure - General Questions
    Last Post: May 10th, 2011, 12:42 AM
  4. Rst 2012
    Last Post: April 26th, 2011, 03:21 PM
  5. 3D Section Drawing
    By Kcooke in forum Architecture and General Revit Questions
    Last Post: December 15th, 2010, 09:21 AM
