Thread: Upgrading Projects & Revit.INI
    6,389
    07:54 AM
    For some reason I recall there being a switch that can be included in the INI file to enable / disable a dialog box asking if the user wants to upgrade a project to the newest version. Am I delusional in that or am I just not finding it?
    Is it Friday yet... ?
    Member pivoarch's Avatar
    March 16, 2011
    Princeton, NJ
    362
    07:54 AM
    Google says you are delusional and it is not Friday. I will keep searching now though because I am curious.
    Long Beach, CA
    208
    04:54 AM
    As Rob noted, i don't think there is a setting. AFAIK. it's just a new feature that was added to Revit 2016. I'm not sure why anyone would want to disable this behavior, in the project setting at least, so i'd be surprised if adesk provided that flexibility.
    Jon
    3,167
    04:54 AM
    If that is possible then the dialog that appears would likely include a check box option to disable showing it in the future and I don't recall it having that option. Also the way it works, it does not stop upgrading the file, it only allows us to cancel the opening/upgrading of the file if that takes long enough for us to click Cancel. That means disabling the dialog from appearing would effectively eliminate the new feature from existing at all...it would upgrade files like it used to without any opportunity to avoid it happening.
    Autodesk JeffH's Avatar
    807
    07:54 AM
    If that is possible then the dialog that appears would likely include a check box option to disable showing it in the future and I don't recall it having that option. Also the way it works, it doesn't not stop upgrading the file, it only allows us to cancel the opening/upgrading of the file if it takes long enough for use to click on Cancel. That means disabling the dialog from appearing would effectively eliminate the new feature from existing at all...it would upgrade files like it used to without any opportunity to avoid it happening.
    This pretty much covers it. There is not an INI switch to toggle the upgrade information box. The ability to cancel is all that was added.
    6,389
    07:54 AM
    Thanks. Not sure why I thought there was a confirmation dialog... long day yesterday
    Last Post: May 11th, 2015, 11:15 AM
  2. BimBlog: Beware upgrading to Revit 2015 R2...
    By BimBlog in forum Blog Feeds
    Last Post: December 11th, 2014, 05:45 PM
  3. Add-Ins and Upgrading Revit
    By Cyus in forum Third party Add-Ins, API and R&D
    Last Post: May 7th, 2014, 12:54 PM
  4. Upgrading projects to 2014
    By Kate1053 in forum Structure - General Questions
    Last Post: July 12th, 2013, 12:04 PM
  5. Revit OpEd: Upgrading and Reloading Families
    Last Post: December 6th, 2012, 01:15 PM
