Results 1 to 10 of 10
Thread: Family Type Parameter Help
    August 11, 2015
    4
    12:05 AM
    So, I am attempting to build a condensing unit that will have 4 different length legs.
    I built the legs in individually families with each leg length as a type. Currently the unit is offset the same distance as the length of the legs; and they adjust in sync with each other as necessary. This is working by typing in the length you want.
    My issue is how do I restrict the leg height to only the types that I created? I do not necessarily want to be able to build say a 13” leg when all I need is a 6, 12, 24 and 36 inch leg length.
    I thought using a family type parameter would work, however the types are not changing in the project environment as many “you tube” videos suggested they would.
    The second part of this is if I am able to create the types using the family type parameter, how do I ensure the offset of the unit will match the length of the leg?
    I am trying to avoid using visibility parameters.
    Currently the two parameters I am working with are “H of leg” and “Leg Type<Generic Models>”
    Any thoughts or suggestions would be greatly appreciated.
    Attached is a 2016 model.
    6,312
    01:05 AM
    To use Types the nested family needs to be shared.
    The other option is what will probably end up becoming a long formula: http://www.revitforum.org/tutorials-...day-usage.html
    if(LegLength<6",6",if(LegLength<12",12",if(LegLeng th<24",24", etc (I haven't tried that - you may need some Not or And statements.)
    3,215
    01:05 AM
    To use Types the nested family needs to be shared. ...
    No, is not necessary that the nested families are shared.
    3,215
    01:05 AM
    ...The other option is what will probably end up becoming a long formula:...
    Not necessary, either. Simply tie the instance Height parameter of the nested leg to a local type Height parameter. If the legs have different features, use a type parameter with a label to control the type of leg. Move the box up as per the same Height parameter. See illustration and attached sample family (2016 format).
    August 11, 2015
    4
    12:05 AM
    Thanks
    Hey Thanks for the input, I will let you know how it works out.
    6,312
    01:05 AM
    fail on my part!
    I was using the formula to restrict the sizes available per the OP's question:
    Quote Originally Posted by laBaumba View Post
    My issue is how do I restrict the leg height to only the types that I created? I do not necessarily want to be able to build say a 13 leg when all I need is a 6, 12, 24 and 36 inch leg length.
    That could be done by only have predefined types available but there isn't anything stopping someone from creating a leg that is 13" that way.
    August 11, 2015
    4
    12:05 AM
    So, I have the predefined types. However, they are not appearing when chosen. I looked at Medina's family and am unsure how his is different than what I currently have. When using his family type parameter, the legs change shape. Mine are currently not different shapes, but they are different heights. However, when I change the type, nothing happens. So, I assume there is a disconnect somewhere, but not sure where... the hunt continues.
    May 6, 2014
    Dallas, Texas
    19
    12:05 AM
    Perhaps I'm misunderstanding the issue, but it seems that the types could simply be achieved by the following steps:
    -Draw reference plane at top-of-legs/bottom-of-unit.
    -Place dimension between Ref. Level and newly created reference plane.
    -Apply "H of leg" parameter to this dimension (make sure it's a type parameter).
    -Set leg extrusion equal to "H of leg" in Properties window.
    -Similarly, lock bottom of unit to reference plane.
    -Create four different family types: one for each "H of leg" value.
    3,215
    01:05 AM
    ...My issue is how do I restrict the leg height to only the types that I created? I do not necessarily want to be able to build say a 13” leg when all I need is a 6, 12, 24 and 36 inch leg length.
    Simply create the types. There is no need to "prevent people from creating a 13" type". Create four types, one for 6, one for 12, one for 24, and for 36. Use the family that I posted as example. Create types there, and see how everything works.
    August 11, 2015
    4
    12:05 AM
    Got It! Thanks for the ideas and the direction GIGI. There was a label not applied to the family in the properties window.
  1. shared family and <family type.....> parameter, when loaded error
    By Bross in forum Structure - Family Creation
    Last Post: November 25th, 2013, 12:56 PM
  2. Type Catalog to family parameter
    By alex60 in forum Architecture and General Revit Questions
    Last Post: June 11th, 2013, 03:48 PM
  3. select by parameter? curtain wall panels' materials by parameter, by type or family?
    Last Post: January 24th, 2013, 03:20 PM
  4. Can you use a 'Family Tpe' parameter in a type catalogue?
    By brett05 in forum Architecture - Family Creation
    Last Post: September 6th, 2011, 07:45 AM
