Thread: Revision schedule
    March 31, 2014
    63
    08:25 AM
    Revision schedule
    Hi all!
    Just want to know is it possible to make revision schedule inside project, as is it possible to make sheet list (see picture)?!
    If not, what is then best practice? Only inside titleblock? Is it possible then somehow to define visibility of the revision schedule so that I can tell to Revit when I want to see that schedule on titleblock and when not?!
    Generally, where do I create revision cloud? On a sheet, or in model space?
    Best regards, Branimir
Name:	Revision schedule.jpg
    Member Exar Kun's Avatar
    August 2, 2011
    219
    05:25 PM
    Cloud on a sheet as the sheet is the document that is being amended.
    June 14, 2011
    CT, USA
    616
    03:25 AM
    We cloud in the model as it is often a sketch that is being submitted and the cloud needs to appear on both the sketch and the original sheet.
    March 31, 2014
    63
    08:25 AM
    Quote Originally Posted by Exar Kun View Post
    Can you explain this a bit more?!
    February 22, 2013
    384
    03:25 AM
    I use Sheet Lists filtered by Current Revision Date to keep a list of all Sheets affected by a Revision. It's very handy for larger revision packages. The rub is that you can't filter by anything other than "Current Revision Date".
    Revit is limited in how you can work with Revisions. I've been playing a round with Dynamo to get around some of those limitations. See my posts in this thread:
    http://www.revitforum.org/dynamo-bim...arameters.html
    In my case, I've been trying to create a Dynamo definition that will auto-generate a Revision Narrative document. It's like 95% done, but I'm a bit lost in the weeds with it.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,570
    12:25 AM
    FYI sheet lists to keep track of Revisions can be filtered by Current Revision, Date, Description, Issued, Issued By, or Issued To
    February 22, 2013
    384
    03:25 AM
    Sorry, what I meant to say was that you can't sort by any other Revision date than the current one.
    Dave Jones's Avatar
    4,570
    12:25 AM
    ah, sorry that I misunderstood
  1. Revision Schedule
    Last Post: August 19th, 2015, 11:53 AM
  2. 2015: Revision Schedule
    Last Post: July 27th, 2015, 04:23 PM
  3. Revision Cloud Schedule
    Last Post: June 16th, 2015, 07:55 PM
  4. revision clouds in legend views do not generate revision schedule entries
    Last Post: July 1st, 2013, 10:39 PM
  5. Tekeningenlijst/schedule van sheets met revision schedule
    By rijber in forum Nederlands forum
    Last Post: February 2nd, 2013, 01:50 PM
