Thread: Gid center lines in ceiling view
    December 11, 2014
    6
    08:27 AM
    hey there
    I want to show the "grids center line" in the plan view and hide it in the ceiling view ,there is any way to help me with this issue.
    I hope I can find a solution here
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,522
    01:27 AM
    If I understand your question correctly you would make sure that "Grids" is checked under visibility/graphics (Annotation tab) for the floor plan view and unchecked in the ceiling plans. If this is a project or firm wide standard make view templates with that setting.
    December 11, 2014
    6
    08:27 AM
    thanks for you
    but I want to keep the grids visible and hide only the center line of the grids
    if there is any possible way to do this .
    December 31, 2012
    NM, USA
    1,522
    01:27 AM
    Ah - you manually reduce the grid center line length, but there isn't a way to do it automatically, you'd need to modify each grid on each sheet. There isn't a way to break the line like you can with sections either. Make sure you click on the 3d text to change it to 2d or it will mess up your floor plans!
    December 11, 2014
    6
    08:27 AM
    Thanks again but i want to hide it at all in specific plan views not reducing it
    I
    December 31, 2012
    NM, USA
    1,522
    01:27 AM
    I'm not aware of a way to do it in default Revit. Perhaps if you look into the api?
  1. Demolish Ceiling Grid and dashed lines
    Last Post: December 19th, 2019, 12:01 AM
  2. Use of Center Lines in Dimensioning Certain Building Objects
    By colokate in forum Architecture and General Revit Questions
    Last Post: March 24th, 2015, 04:12 PM
  3. Revit OpEd: Insert using Auto-Center to Center
    Last Post: May 30th, 2014, 06:15 PM
  4. Replies: 1
    Last Post: February 16th, 2012, 05:18 AM
  5. How to view Section view lines on a plan view bigger than 1:100 scale
    By eks_al in forum Architecture and General Revit Questions
    Last Post: January 18th, 2012, 12:41 AM
