Results 1 to 10 of 15
Thread: Invisible room tags (Revit MEP)
    July 22, 2011
    07:33 AM
    I am using Revit MEP and trying to place room tags into a building that is a xref of Revit architecture. As I am about to place the tags, I noticed that it reads the original room names from the Revit Architecture file. But when I click to place the room tag an error pops up saying that the tag is not visible in the current view (which is a floor plan so it should). I tried ajdust my visibility/graphics, the view range, and my worksets are all set up as they should be. I tried utilizing the space naming utility but this was unsuccessful becuase the spaces would load but, again, there were no room tags. Does anyone know anywhere in the program where my views or visiblity might not be set up right, or know the sollution to this problem???
    Member Jrobker's Avatar
    Salt Lake
    178
    12:33 AM
    Quote Originally Posted by Justin8304 View Post
    I'm not sure if your using the wrong nomenclature, but you should be using space tags not room tags.
    Keep in mind:
    Your cut plane has to go through the space in order for the tag to be visible.
    Room bounding checked
    Space tags visible in VG
    Member Gabriel Black's Avatar
    April 6, 2011
    Belgium
    203
    10:33 AM
    Room Bounding checked is very important!
    August 5, 2011
    03:33 AM
    I am facing the same kind of problem. I linked architectural model in Revit MEP and my all settings are proper for visibilty/graphics for space and space tags. The issue is that when I am using Space Naming Utility or tagging space using Space Tag it's not detecting room names and number. Morover when I select the space, the room numbers and room names are not showing up even in properties which they supposed to be. I checked Architectural Model and I found that rooms are in another design option but that design option is set as primary option. I also tried to keep that design option as current design option in Revit Linked file from Visilility/Graphics, but it also didn't work. So any suggestion????
    Salt Lake
    178
    12:33 AM
    Rooms CAN exist in design options, spaces CANNOT exist in design options. What you can do is force your view to see that of a linked view to get your room names.
    August 5, 2011
    03:33 AM
    Design options are set on architectural model not MEP file. And all room annotation are on in MEP file as well as linked architectural model still it's not showing up.
    April 6, 2011
    Belgium
    203
    10:33 AM
    I had a similar problem a couple of days ago. It took me hours to realize what I'd done wrong:
    I was making insulated rooms and labeling them with my newly made, hot, shiny room lables when there was this one room that was really giving me grief. It'd tell me there was a lable already assigned to it. I'd float over it and sure enough, it was there. I'd delete it, re-do it, re-name it and STILL it wouldn't show! It was there, but invisable!
    It took a long time for me to realize that I'd placed a ceiling in the room - just like the others - except this ceiling was lying on the floor! Of course I'm not going to see a room lable on the ground if there's a ceiling lying on top of it! I put the ceiling on the correct level and BINGO! Room lable visable.
    I'm such a pleasant idiot...
    August 5, 2011
    03:33 AM
    That seems Really interesting!!
    Salt Lake
    178
    12:33 AM
    Quote Originally Posted by CHintan.thakkar View Post
    What I'm trying to tell you is, spaces do not recognize design options rooms, linked or not. If the Architect is using design options than forget using space tags. You'll have to do what I said in my previous post or create "Dummy" room names.
    November 24, 2015
    9
    02:33 AM
    Has anyone actually solved this issue? A coworker and I are going through the same deal.. with no luck. Everything we know to check seems correct, and on multiple projects prior have never had an issue with using room tags. Now, both plumbing and electrical plans have this issue but HVAC plans seem fine. Is there something possibly in the view template that's not under "Annotation" or "model" v/g overrides?
    We are using Revit MEP 2016 with a linked Architectural model from an outside source.
  1. Revit Kid: Revit MEP - Should we model the Existing?
    Last Post: July 18th, 2011, 02:30 PM
  2. Replies: 6
    Last Post: July 12th, 2011, 07:48 PM
  3. Transitioning from AutoCAD MEP to Revit MEP
    By tzframpton in forum MEP - General
    Last Post: May 16th, 2011, 01:41 PM
  4. Family Origin & invisible ligns
    By jameshs in forum Architecture - Family Creation
    Last Post: December 31st, 2010, 05:00 PM
