Thread: Corner conditions for radiant panel
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    220
    03:53 PM
    How do people handle the corner conditions of their radiant panel families? (Specifically for mitered corners). I want to have my rows be an array but I can't figure out if it is possible to have the line lengths be different.
    Should I have a different family for each number of rows/panel width, or should I use visibility controls of the lines instead?
    1,405
    11:53 PM
    do you have an example family?
    December 29, 2014
    Calgary, Canada
    220
    03:53 PM
    Basically I want to be able to control the angle of each end of the panel, have interior line work representative of the amount of rows in my panel (I am trying to use an array), and have the lines constrained to each end.
    1,405
    11:53 PM
    had a look...but i cant make it work either.
    I have made symbols with lines like this before but with a fixed number of lines. If you lock them to the outside lines they do adjust with size, however because the number of lines stays the same you might get an empty corner..
Name:	line array.PNG
    Might work better with actual model geometry. If anyone else has a fix for this it would be good to know.
  1. Corner Panel
    By pjetrus in forum Architecture and General Revit Questions
    Last Post: September 24th, 2015, 12:12 PM
  2. Custom Curtain Wall Panel Corner Condition
    By BLothian in forum Architecture and General Revit Questions
    Last Post: October 6th, 2014, 04:02 PM
  3. Curtain Panel with Voids for Angled Conditions
    Last Post: April 22nd, 2013, 05:20 PM
  4. Replies: 1
    Last Post: September 7th, 2011, 06:04 AM
  5. Corner Panel Model In Place
    Last Post: June 26th, 2011, 09:53 PM
