Results 1 to 3 of 3
Thread: Any way to de-activate automatic structural members connections?
    Member gpktm's Avatar
    October 22, 2012
    Melbourne, Australia
    150
    02:22 PM
    Angry Any way to de-activate automatic structural members connections?
    Hi everyone
    Is the any way to de-activate the annoying and useless auto-extension/trimming that revit does with structural framing and columns? Almost in every project is giving me a lot of frustration and 9 out of 10 times it won't do what I'm actually expecting it to do.
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    307
    11:22 PM
    You can modify a beam family by constraining the extrusion to these reference planes (see image below).
    Or you could just "select all" and change the start/end extension values to 0'-0".
    If you want this done automatically, you might consider Dynamo as an option. Here's a pretty quick and simple script:
    October 22, 2012
    150
    02:22 PM
    Unfortunately "extension" settings do not work, at least not in my case. I have created a frame and made a group of all structural components, two of them are identical but one of them for some reason differs. When I extend the length in the one that's different, the other two are also effected and then are extended beyond the point I want. But this is just a specific example, my issue is autoextension and auto connections in general, many times Revit behaves by brining undesirable results or even updates automatically the connections when another member that effects the connection is changed. So I need a way to override that function if possible.
    Here's is another example. I had some base frames where the perimeter beam had mitre cut on each corner, after working on the rest of the framing, I suddenly realised that Revit broke the mitre connection on one of the base frames as you see in the picture (they one I've selected).
  1. Activate Dimensions
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: October 5th, 2018, 07:46 PM
  2. Activate Offset Box ?
    By mark b in forum Architecture and General Revit Questions
    Last Post: September 12th, 2017, 04:34 PM
  3. Structural Framing members under (hidden) not showing hidden
    By maheshn in forum Structure - General Questions
    Last Post: December 4th, 2014, 01:44 AM
  4. Structural Members and Masked Regions
    By dzatto in forum Architecture and General Revit Questions
    Last Post: January 7th, 2011, 05:22 PM
  5. Structural Members
    Last Post: December 22nd, 2010, 06:04 PM
