Thread: Section lines not appearing in exported dwg floor plan
    January 26, 2016
    07:27 AM
    Angry Section lines not appearing in exported dwg floor plan
    Hi all,
    When exported a floor plan to a DWG file the section lines do not appear. I can view them on screen and they appear when the floor plan is printed but do not appear in an exported dwg file.
    Can anyone shed some light on this issue?
    June 14, 2011
    CT, USA
    616
    03:27 AM
    If the section view is not on a sheet, uncheck this setting.
Name:	Unreferenced view tags.PNG
    Member truevis's Avatar
    January 7, 2011
    112
    03:27 AM
    Had the same problem. Threw all the section views onto a sheet, then the section lines exported in the DWGs.
  1. Section markers not appearing
    Last Post: November 24th, 2016, 07:51 AM
  2. symbole lines not appearing in elevation
    By sgray05 in forum Architecture and General Revit Questions
    Last Post: August 5th, 2015, 06:58 PM
  3. Objects appearing underneath Floor Plan
    By JPREng in forum Architecture and General Revit Questions
    Last Post: November 5th, 2014, 05:13 AM
  4. Model appearing as 2D lines in Navisworks
    By Hangman in forum Coordination Tools
    Last Post: February 25th, 2014, 02:26 AM
  5. Parts division lines is not showing in floor plan ?!!
    Last Post: December 22nd, 2011, 03:34 PM
