Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: Get name of the space/room where an element is with Dynamo
    August 29, 2015
    105
    01:18 PM
    Hi!
    Is it possible to get the name of the space/room where an element is with Dynamo?
    In Schedule it is possible to filter by "Space: Name" and/or "Space: Number" (Image1). Is it possible to do somthing similar in Dyname? Look at "Image2" there i tryied but i got nothing in my Watch-node.
    Best regards Engineer
ID:	25339   Click image for larger version.
    6,389
    09:18 AM
    Member johnp's Avatar
    March 24, 2015
    178
    06:18 AM
    Going to upload this to Rhythm right now too.
Name:	2016-01-27 15_16_51.png
    August 29, 2015
    105
    01:18 PM
    Thank you johnp! I tried Element.Space and it works fine with all elements exept with Cable Trays! Is there a way to make it work with Cable Trays?Click image for larger version.
    March 24, 2015
    178
    06:18 AM
    Hmm.. Seems possible, what would you expect it to do?
    Figure out if the cable tray is above the space?
    Or completely enclosed in the volume of the space?
    March 24, 2015
    178
    06:18 AM
    This version will determine which space the center point of a cable tray falls within.
    August 29, 2015
    105
    01:18 PM
    To check the center point will work good in my case, so i think that node "CableTray.Space" will be my solution. I want to try it tomorrow, how do I get the CableTray.Space-node? Is it in a new Rhythm-package?
    March 24, 2015
    178
    06:18 AM
    I will publish this to Rhythm today. Are you on Dynamo 1.0?
    August 29, 2015
    105
    01:18 PM
    That would be great! Iam in Dynamo 0.9.2. but I have no problems to install 1.0 as well.
    August 29, 2015
    105
    01:18 PM
    Is it published? The latest I can se is from april.
  1. slanted wall vs space/room
    Last Post: September 17th, 2019, 06:27 AM
  2. space&room or spase
    By UNikolai in forum Dynamo BIM
    Last Post: December 4th, 2015, 10:03 AM
  3. room separator line space tolerance
    Last Post: March 11th, 2014, 09:13 AM
  4. Find Room Element by Room Number?
    Last Post: September 17th, 2013, 05:22 PM
  5. Space / Room linking issue
    By Steven Thedens in forum MEP - General
    Last Post: December 7th, 2012, 09:03 PM
