Thread: How do I make a pipe hosted family automatically size itself?
    February 5, 2016
    04:50 PM
    As the title implies, I need to create a pipe based family that sizes itself based on whatever pipe it is attached to.
    I have already gotten a lookup table filled out and working for the family, the only problem is that it is not adjusting it's size based on the pipe.
    Attached for convenience is the Family
    September 16, 2015
    Darwin, Australia
    169
    09:20 AM
    Hi Woodruff,
    You need to change your family category to Pipe Accessory rather than Plumbing Fixture, I set the part type to Inline Sensor and it seemed to work. That will fix your auto-sizing issues.
    If you need further explanation please leave a reply, good luck.
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    465
    03:50 PM
    Make sure the family is a Pipe Accessory and change the sizing parameter to be an instance based parameter and it will autosize to whatever it is attached to.
    Senior Member Darius's Avatar
    May 6, 2013
    501
    06:50 PM
    is there certain family template you have to use to get this to work? I have a clevis pipe hanger that will align with the pipe but will not go to the correct elevation or move with the pipe.
  1. Pipe fittings are not the right size........
    By rogpatt in forum MEP - General
    Last Post: October 14th, 2015, 04:27 PM
  2. Make Junction Box Hosted
    By CRapai in forum MEP - Family Creation
    Last Post: May 26th, 2015, 02:41 PM
  3. pipe size in schedule
    Last Post: April 8th, 2014, 03:38 PM
    Last Post: November 22nd, 2013, 05:16 AM
  5. Cannot use decimal in pipe size
    By Jrobker in forum MEP - General
    Last Post: November 21st, 2013, 10:46 PM
