Results 1 to 10 of 12
Thread: Linked File Displaying Pattern Differently
    Moderator Drew's Avatar
    Perth, Western Australia
    691
    03:32 AM
    Hi all,
    The team have come across a really interesting issue today. We have two linked files, one Architectural and one Structural.
    There has been a filter created to apply a cross hatch to the surface. They have been created on the same level, no offset. They are both floor's. All in all, they should be the "same".
    When the filter is applied, one shows the pattern correctly, one shows the pattern heavier and a different colour.
    I have tried transferring project standards as well, still no change.
    Has anyone seen this before and can shed some light on it for me?
    3,157
    01:32 PM
    Probably not what you want to hear, but I believe Filters do not work on Linked models.
    Edit: I stand corrected.
    10,716
    01:32 PM
    Sure they do. I use Filters on Linked Models all of the time.
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    271
    07:32 PM
    Are the floors both in the same phase in the two models?
    691
    03:32 AM
    Hi Dave,
    Yeah they do, been using them for a while now. ��
    I spent a large portion in fresh files testing today and all works as expected. These project files though are a bit odd.
    I'm thinking it might have something to do with the view template. I did notice there were a lot of filters and I think there might be multiple filters trying to adjust the same elements, in different ways.
    10,716
    01:32 PM
    Phase Overrides, Line Weights, Line Types, Object Styles, and Line Styles might be different in the other file. Even with Filters, its not a safe assumption that the other file will react to the Filter the same way yours will, unless those settings are identical in the different file.
    August 13, 2011
    22
    11:32 AM
    Is lineweight 1 set to the same thickness in both files? That lineweight controls fill patterns. It will use the lineweight setting in the structural file when displayed through a link.
    Rafael Alvarez
    Gehry Partners LLP
    Member jsnyder's Avatar
    AUGI Refugee
    352
    11:32 AM
    We just ran into a situation today where someone changed a phase filter setting in a linked file and it stopped showing up in the target file. It took quite a while to track that one down through the 33 things...As Aaron says, my guess is to look in the VG settings in the link for the source.
    691
    03:32 AM
    Hmmm, good point. I didn't check the phase overrides.
    All of the other items have been address with manual checking and TPS, so I am confident that they are consistent across the files.
    The line weight for "1" will address the surface pattern issue, but the doesn't address the projection and cut lines, I have noticed that this situation is now occurring in elevations and sections with the linked files!
    The interesting thing is, these are consultant files and as such will by default have very different line weight and object style settings as their documentation relies on it. I guess I need to ask for some views which we can use as linked views, not too much of an ask for plan views, a bit of a stretch for sections and elevations
    I did also notice that the linked file has been changed to custom in the VG (I have no idea why....yet) and with a view template applied my experience is this can be problematic.
    10,716
    01:32 PM
    By itself, that information (having the linked model set to Custom) doesnt mean something bad was done... I have every single linked model set to Custom in every single View i have. Thats specifically what i have my view templates do.
  1. Why is this standard storefront wall displaying differently in elevations
    By Tony Phillips in forum Architecture and General Revit Questions
    Last Post: October 14th, 2015, 03:33 AM
  2. How can I make the hatch pattern from a linked Revit file turn off?
    Last Post: June 9th, 2013, 01:35 AM
  3. Linked file 'masking' over area fill pattern
    Last Post: May 2nd, 2013, 12:02 AM
  4. Linked Revit file hatch pattern isn't showing?
    By kcaparella in forum MEP - General
    Last Post: January 11th, 2012, 06:05 PM
  5. Pattern V/G override for linked file disappears when link was replaced
    By ekkonap in forum Architecture and General Revit Questions
    Last Post: July 10th, 2011, 09:29 PM
