Thread: Annotation Family leader
    Member cganiere's Avatar
    January 5, 2011
    217
    04:40 PM
    When my annotation tag has multiple lines the leader centers in the block of text like so: Click image for larger version.
    The red line shows where I want the leader.
    Here is what the properties box shows in the family editor: Click image for larger version.
    What am I doing wrong?
    Chris
    2,689
    05:40 PM
    Nothing. Leaders start at the midpoint of the family extents. Create a couple of invisible lines in your family equally spaced above and below the midpoint of the top line and you should be good to go. I have mine set to a formula that changes the distance between them based on the number of lines of text.
    January 5, 2011
    217
    04:40 PM
    Greg, thank you! The formula works like a charm.Click image for larger version.
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    372
    01:40 PM
    Works really well
    Never though of doing that formula wise!
    Our default one has some interesting behavioural problems:
    If your Text gets deeper than the extent of the Invisible Lines in the family, and then the leader can't snap to a horizontal line
    If we adjust the Invisible lines to much, the Move/Stretch Point also moves down out of sight too
  1. Create an Annotation with an Arc Leader
    By robieszuds in forum Architecture and General Revit Questions
    Last Post: January 12th, 2019, 02:52 PM
  2. Replies: 15
    Last Post: March 5th, 2017, 06:01 AM
  3. Replies: 1
    Last Post: January 22nd, 2016, 04:18 PM
  4. Generic Annotation Leader attachment
    By jake.b in forum Architecture and General Revit Questions
    Last Post: November 30th, 2015, 06:36 PM
  5. Generic Annotation Leader Line Length
    Last Post: May 15th, 2014, 08:20 PM
