Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Beam Join/Miter Tool is finnicky
  1. #11
    890
    04:12 PM
    Revit does some weird structural priorities and this is one of them Limbatus.
    It says that the column is a support, and therefore more important than the beam. But if you manage the height of the column properly it should be ok.
    I've never messed with it too much, but changing the structural usage and analytic conditions it may also change the behavior.
    Also if you aren't using it, try turning off the analytic model for those components and this can often change the behavior also.
  2. #12
    December 11, 2019
    12:42 PM
    Thank you so much! That's the point i wanted to know !!
  1. Sweep wont miter
    By HenryD in forum Architecture and General Revit Questions
    Last Post: July 4th, 2011, 12:13 PM
  2. Miter a steel tube?
    Last Post: April 29th, 2011, 12:57 PM
  3. beam/column join to create "rigid frame"
    By Scott Webb in forum Structure - General Questions
    Last Post: April 28th, 2011, 06:29 PM
  4. Miter detail components
    Last Post: April 21st, 2011, 12:01 AM
  5. Miter Curtain Wall Glazing
    Last Post: March 24th, 2011, 03:39 PM
