Results 1 to 10 of 14
Thread: Renaming Materials - Only Working on Some Materials
    6,388
    06:19 AM
    I'm trying to do some material organization and am getting partially there but am stumped on why the Dynamo graph only works on some of my materials.
    I can export all the material names & IDs to excel with no problem. In Excel I have sorted and done all my renaming, then sorted back to the original sort order from the export (by ID.) When I run the graph to import the Excel data it will work on about half of the materials but I can't figure out the rational behind what renames and what doesn't
    There are some materials that I'm not renaming, mostly OOTB materials (Default Roof, Default Wall etc) but quite a few of the materials that should get renamed aren't. Do I need to exclude the materials that aren't changing or am I doing something else wrong?
ID:	26523   Click image for larger version.
    November 21, 2012
    Boston, MA (USA)
    612
    12:19 PM
    If you try manually (single nodes with isolated elements) changing one of the materials that isn't playing nice - does it work?
    If so - there is some form of broken logic in your graph. If not - there is some form of issue with the material!
    6,388
    06:19 AM
    And today it doesn't work at all
    I love hate want to understand Dynamo more
    November 21, 2012
    Boston, MA (USA)
    612
    12:19 PM
    Did you upgrade to Dynamo 1.0.0 perchance?
    If so all packages, until updated, will probably fail. There's some underlying API changes (Hopefully the last major set until 2.0.0) that have broken things.
    6,388
    06:19 AM
    Quote Originally Posted by amoursol View Post
    I did, but it wasn't working before that.
    6,388
    06:19 AM
    Looked at this again and got it to work with a little tweaking based on this post on the Dynamo forum: Topic: Change material names? | Dynamo BIM
    Excel file had 4 columns:
    Original Material Name
    Material ID
    New Material Name
    Material ID
    Script really only needs the names but the ID is a good cross reference.
    May 20, 2011
    20
    12:19 PM
    Hi there,
    Q. What Dynamo package did you get "Read Excel" because mine has less functionality.
    Thanks.
    Rob
    May 20, 2011
    20
    12:19 PM
    January 19, 2012
    348
    06:19 AM
    Are you referring to the "Material ID" as the "Element ID" & or could it also be the "Unique ID"?
    6,388
    06:19 AM
    Quote Originally Posted by cftrevizo View Post
    Sorry about that. You are correct: Material ID = Element ID, pulled using the Element.ID node.
  1. Renaming Families en masse
    Last Post: July 15th, 2015, 02:22 PM
  2. Subcategory renaming add-in out there?
    By Tim Waldock in forum Third party Add-Ins, API and R&D
    Last Post: July 13th, 2015, 12:51 PM
  3. renaming levels.
    By leetecture in forum Architecture and General Revit Questions
    Last Post: June 17th, 2013, 10:20 PM
  4. Phase Renaming
    By mfrietze in forum Architecture and General Revit Questions
    Last Post: October 7th, 2011, 10:00 PM
